Hello Guest it is November 10, 2026, 02:17:37 AM
Author Topic: help needed with atc macro for mill retrofit  (Read 29936 times)
« on: March 14, 2017, 12:37:30 AM »
Hello all, I'm new to the forum but not cnc or mach3(have several machines running it) recently retrofitted a mill (denford triac) and i'm stumped with the atc macro. Any help will be appreciated at this point. The part i'm having an issue with is, i want to activate output 7(while input 1 is active)and have output 7 remain on until input 1 goes inactive and returns active again then deactivate output 7.
some info..
The input is a proximity sensor on the geneva gear drive thats shaped like 3/4 of a circle and is active on the missing 1/4 section
tool charger is 8 position
relays ect are setup
its a reversible ac gear motor driving a geneva gear
1 relay is motor power 1 for reversing
has proximity sensor which i have wired to a relay that grounds a pin to activate (input1)
ive started with a macro i found and edited (for better or worse...)the section below between the "#######" is the main issue but any help is welcome this is v1.0 after all...
Sub Main()
'Global variables declaration
NewTool = GetSelectedTool()
OldTool = GetCurrentTool()
While NewTool > 8
NewTool = Question ("Enter New Tool Number up to " & MaxToolNum)
Wend
If NewTool = OldTool Then'Compare between actual tool and requested tool
   Else
   End If
If NewTool > 8 Then'requested tool higher then tool numbers
   Else
   End If
If NewTool < 1 Then'tool number to low
   Else
   End If
code("m05")
   Call ZatcPosition
   Call AtcIn'Activate air cylinder valve to put old tool back to carrousel
   Call Unclamp'Spindle: Tool Unclamp
   Call AtcDown'lowers atc
   Call LeastTravel'determine the least travel to move and Turns CW or CCW
   Call AtcUp'raises atc
   Call Clamp'Spindle: Tool Clamp
   Call AtcOut'retracts atc
   Call SetUserDRO (1200,NewTool)'Store new tool as actual tool value
SetCurrentTool( NewTool )
End Sub
Function ZatcPosition()'Move to Z tool position and wait until position reached
   code("G53")'Move in Absolute Machine coordinates
   code("G00 Z-1") 'Z value as to be checked for exact match with carrousel height
   While(IsMoving())
      Sleep(100)'temporisation entre while++
   Wend
End Function
Function AtcIn()'Put old tool back to carrousel
      ActivateSignal(OUTPUT4)'Move carrousel air cylinder to the tool change position adjust output# to match atc slide
      code("g04 p01")
End Function
Function Unclamp()'Spindle: Tool Unclamp
       ActivateSignal(OUTPUT6)'Release the tool, adjust output number for drawbar output
code("g04 p01")'pause
End Function
Function AtcDown()'lowers atc to rotate
   ActivateSignal(OUTPUT5)'solonoid to lower atc
   code("G04 p01")'pause
End Function
'Sequence to determine the least travel to move for TC, CW or CCW
Function LeastTravel()
   NTool = 8 ' Number of tools changer holds
   CWPos = GetSelectedTool() - GetCurrentTool() ' Assume a CW move
   If CWPos < 0 Then ' CWPos < 0 ==> rtp < atp
      CWPos = CWPos + NTools
   End If
   CCWPos = NTools - CWPos
   If CWPos < CCWPos Then
      Call CW()
   Else
      Call CCW()
   End If
End Function
Function CW()'Rotation CW
   Dim x As Integer
   Dim CTPos As Integer 'Carrousel Tool Position Relative to OldTool Position
   CTPos=0
   ActivateSignal(OUTPUT7)'Turns the AC Motor On
   code"g04 p05"
   Do Until IsActive(input1)
   deactivatesignal(output7)
   sleep(0)
   Loop
      For x=0 To CWPos
         If IsActive(input1) Then
            x=x+1
            While IsActive(input1)'Wait for OEMTrig to de-assert
            Wend
         End If
      Next x
      CTPos=x
   DeactivateSignal(OUTPUT7)
End Function
Function CCW()'Rotation CCW
   Dim y As Integer
   CTPos=0
   activatesignal(output8)'atc motor revirsing relay
   code"g04 p05"
   sleep(0)
   Loop
   For y=0 To CCWPos
      y=y+1
         Wend
      End If
   Next y
   CTPos=y
   deactivatesignal(output8)
End Function
Function AtcUp()'lifts atc
   deActivateSignal(OUTPUT5)'relay for solonoid to lower/lift atc
End Function
Function Clamp()'power drawbar unactivated
   DeactivateSignal(OUTPUT6)'unactivating drawbar relay
End Function
Function AtcOut()'retracts atc
      deActivateSignal(OUTPUT4)'atc retract cylinder relay
      code("g04 p01")
End Function
Main
Offline TPS
  •  2,627 2,627
Re: help needed with atc macro for mill retrofit
« Reply #1 on: March 14, 2017, 04:34:20 PM »
ok lets try to read your code:
   Dim x As Integer
   CTPos=0
--> some declarations
--> Switch Output 7 on
   code"g04 p05"
--> wait a Little bit
   sleep(0)
   Loop
--> Switch Output 7 on and off until input1 is on makes no sence
--> sleep(0) also senseless
      For x=0 To CWPos
            x=x+1
            Wend
         End If
      Next x
--> CWPos is no global variable and no Inputparameter of the function so nothing will happen
      CTPos=x
--> will be Zero, see Problem of CWPos
--> Switch Output7 off , so it only will be on for G04 P5 nothing else
Regards Thomas
« Last Edit: March 14, 2017, 04:36:07 PM by TPS »
« Reply #2 on: March 14, 2017, 05:01:23 PM »
Willing to try any suggestions you have and i appreciate the reply. If you have some code i can replace the section im having trouble with and see what happens i can do that.
Offline TPS
  •  2,627 2,627
« Reply #3 on: March 14, 2017, 05:05:48 PM »
no i have no code to replace,
tryed to make you think about your code.
« Reply #4 on: March 14, 2017, 05:27:59 PM »
i appreciate the attempt but im not sure whats required to achieve my goal I've attempted to look at probing macros ect to learn as they would do a similar task
(if probe input is active move Z+ if not active move Z-)
i'm getting many errors when trying to use the vb editor and not sure how to correct them.
a simple form of what i'm trying to achieve is
turn output 7 on until input 1 is NOT active (when initially turned on the input 1 will be active/home)
(then what ever option is easier)
(option 1) have output 7 remain on until input 1 returns to an active state
(option 2) have it shut off once input 1 is NOT active  then turn back on until active again
this cycle above will make it rotate the atc 1/2 of a tool distance so that ran twice will be equal to  1 tool position.
in non vb editor correct form...
activatesignal(output 7) until input 1 is not active
then deactivatesignal(output1)
next
activatesignal(output7) untill input 1 is active
then deactivate signal (output7)
loop the above the amount of times required to get to new atc position (i can work on this part after if needed)
Offline TPS
  •  2,627 2,627
« Reply #5 on: March 15, 2017, 11:38:12 AM »
ok made some changes in your code:
Code: [Select]
Sub Main()
Dim CCWPos as Integer
Dim CWPos as Integer
While NewTool > 8
Wend
   Else
   End If
   Else
   End If
   Else
   End If
code("m05")
   Call ZatcPosition
End Sub
   While(IsMoving())
   Wend
End Function
      code("g04 p01")
End Function
End Function
End Function
   End If
      Call CW()
   Else
      Call CCW()
   End If
End Function
   Dim x As Integer
   CTPos=0
   Deactivatesignal(output8)'atc motor revirsing relay
   code"g04 p05"
sleep(10)
   Loop
      For x=0 To CWPos
            x=x+1
            Wend
         End If
      Next x
      CTPos=x
End Function
   Dim y As Integer
   CTPos=0
   Activatesignal(output8)'atc motor revirsing relay
   code"g04 p05"
sleep(10)
   Loop
   For y=0 To CCWPos
      y=y+1
         Wend
      End If
   Next y
   CTPos=y
End Function
   DeActivateSignal(OUTPUT5)'relay for solonoid to lower/lift atc
End Function
End Function
      code("g04 p01")
End Function
please try in vbeditor step in mode and Report Errors, sorry have no Chance to test.
Thomas
« Reply #6 on: March 15, 2017, 10:11:39 PM »
Hello, yet again thanks for your help. there is no errors in that macro but it doesn't do what i'm trying to achieve, when i try to go from tool say 1 to tool 2 it just turns on for (about) a second then off getting about half way from t1 to t2. i think the g04 p05 is wrong that was me just trying anything i could think of. What is the correct term for "do until input 1 is not active"? i'm debating replacing the motor with a stepper as i could figure that out but in its current form i seen this atc work with the same sensor/motor/relays on the old less user friendly software so i know it should work.
if i can just get the 2 correct lines for
'activate output 7 until output 1 is not active"
then
"activate output 7 until input 1 is active"
i think it may be a step in the correct direction
   Dim x As Integer
   CTPos=0
   code"g04 p05"
   sleep(10)
« Reply #7 on: March 15, 2017, 10:48:13 PM »
if its of any help i appear to have found the original macro just need it in a format mach 3 can work with ( output/input numbers may vary since i did update the machine)
REM ~~~~~~~~~~~~~~~ Tool Changer Routines ~~~~~~~~~~~~~~
#ArmIn
  GOSUB SpindleStop
  IF !comms(10) THEN RETURN : REM ignore it if we're none ATC
  IF !(OUT & 1) DO : REM Check spindle is stopped
    OUT3 = 1 : REM Switch the solenoid
    REPEAT : REM Wait for the IN switch (inverse logic)
    UNTIL !IN0 OR STOPSW
    WAIT = 500
  ENDIF
RETURN
#ArmOut
  OUT3 = 0: REM Switch the solenoid
  REPEAT : REM Wait for the OUT switch (inverse logic)
  UNTIL !IN1 OR STOPSW
  WAIT = 500
RETURN
#ArmDown
    OUT4 = 1 : REM Switch the solenoid
    REPEAT : REM Wait for the DOWN switch (inverse logic)
    UNTIL !IN3 OR STOPSW
    WAIT = 500
  ENDIF
RETURN
#ArmUp
  OUT4 = 0: REM Switch the solenoid
   REPEAT : REM Wait for the UP switch (inverse logic)
   UNTIL !IN2 OR STOPSW
  WAIT = 500
RETURN
#DrawbarUnClamp
    OUT5 = 1
    WAIT = 500
  ENDIF
RETURN
#DrawbarClamp
  OUT5 = 0
  WAIT = 500
RETURN
#CarouselCW
  IF !IN3 OR !IN1 DO    :REM If arm is back or down
   OUT7 = 1 : REM Set Direction Output
   OUT6 = 1 : REM Set the Power output
   WAIT = 50
   REPEAT
   UNTIL IN4 OR STOPSW
   REPEAT
   UNTIL !IN4 OR STOPSW
   REPEAT
   UNTIL IN4 OR STOPSW
   REPEAT
   WAIT = 40
   OUT6 = 0
   Pocket = Pocket + 1 : REM Inc the Pocket Counter
   IF Pocket > MaxPockets THEN Pocket = 1
  ENDIF
RETURN
#CarouselHalf
  WAIT = 50
  REPEAT
  UNTIL IN4 OR STOPSW
  REPEAT
  WAIT = 40
  OUT6 = 0
RETURN
#CarouselCCW
   OUT7 = 0 : REM Set Direction Output
   WAIT = 50
   REPEAT
   UNTIL IN4 OR STOPSW
   REPEAT
   REPEAT
   UNTIL IN4 OR STOPSW
   REPEAT
   WAIT = 40
   OUT6 = 0
   Pocket = Pocket - 1 : REM Dec the Pocket Counter
   IF Pocket < 1 THEN Pocket =  MaxPockets
  ENDIF
RETURN
#toolChange
  GOSUB SpindleStop
  if !comms(10) THEN Pocket=Comms(7) : REM store last tool if not ATC
  IF (comms(7) = Pocket) OR !comms(10) THEN RETURN : REM ignore it if we're already there or none ATC
  IF !(OUT & 57) DO :        REM If atc is back,Up and drawbar safe
  IF STOPSW THEN RETURN
  GOSUB ArmIn
  GOSUB DrawbarUnclamp
  GOSUB ArmDown
  REM Calculate the shortest path...
  steps = (comms(7) - Pocket + MaxPockets) MOD MaxPockets
  IF steps > (MaxPockets / 2) DO
    WHILE Pocket <> comms(7)
      GOSUB CarouselCCW
    ENDW
  ELSE
      GOSUB CarouselCW
    ENDW
  ENDIF
  GOSUB ArmUp
  GOSUB DrawbarClamp
  GOSUB ArmOut
  ENDIF
RETURN
REM ~~~~~~~~~ End of Tool Changer Routines ~~~~~~~
Offline TPS
  •  2,627 2,627
« Reply #8 on: March 16, 2017, 12:08:31 PM »
Do Until Not IsActive(input1)
   sleep(10)
Loop
Offline TPS
  •  2,627 2,627
« Reply #9 on: March 17, 2017, 04:13:14 AM »
for the moment i am little bit confused about the ligic of input1 for doing one step of ATC
in the original macro:
--> UNTIL IN4 OR STOPSW
--> REPEAT
--> UNTIL !IN4 OR STOPSW
--> REPEAT
--> REPEAT
it looks like it is ON at the start
then OFF ON OFF ON
to do one step at ATC
please describe the pattern of input1 to do one step.
Thomas
