Hello
Guest
it is
November 01, 2026, 11:06:58 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
G-Code, CAD, and CAM
LazyCam (Beta)
Lazycam Crash
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Lazycam Crash (Read 15559 times)
ukkie12342000
7
Lazycam Crash
on:
June 16, 2007, 10:13:55 AM »
Downloaded Lazycam and acquired the license today.
Installed both Lacycam and the license.
But I have no luck so far.
Using the option "offset" and Lazycam crashed at every attempt.
It gives a notification that say's something with "OpenGL" and inform Artsoft.
I have attached the windows error reportmessage.
Kind regards,
Piet Versleijen
Chip
2,055
Gainesville Florida USA
Re: Lazycam Crash
Reply #1 on:
June 16, 2007, 01:11:23 PM »
Hi, Piet
Post your DXF file.
Thanks, Chip
ukkie12342000
7
Re: Lazycam Crash
Reply #2 on:
June 17, 2007, 02:17:52 AM »
Hi Chip,
Here's the dxf.
It's a simple one but with more complicated ones it crashes to.
It is strange that it crashes on both of my computers.
On the older one it crashes without warning or error report.
On the other one I get a warning before lazycam closes.
The warning say's something with "'DrawGL" and contact Artsoft.
Kind regards
Piet
Chip
2,055
Re: Lazycam Crash
Reply #3 on:
June 17, 2007, 02:13:12 PM »
Hi, Piet
Try adding the below file to your c:\Mach3 folder, I've been unable to dup. your problem, Loads and offsets hear fine.
It needs to be Un-Zipped, DLL not in upload Extents.
Let me now if this Helps, Chip
ukkie12342000
7
Re: Lazycam Crash
Reply #4 on:
June 17, 2007, 02:46:34 PM »
Hi Chip,
No luck yet.
Now it gives the same error message on my older system as on the newer one.
I've made a screendump from the message.
Piet
Chip
2,055
Re: Lazycam Crash
Reply #5 on:
June 17, 2007, 04:04:23 PM »
Hi, Piet
Could you post a screen shot of all your dll files, Explorer, Detail, Sort "Type", there may be other dll's your missing.
It did help your old computer some, yes ?
Thanks, Chip
Chip
2,055
Re: Lazycam Crash
Reply #6 on:
June 17, 2007, 07:54:39 PM »
Hi, Piet
Try adding these files also, To your c:\Mach3 folder, There the only one's I have other than whats in the std. LC & Mach3 Installs
ukkie12342000
7
Re: Lazycam Crash
Reply #7 on:
June 18, 2007, 12:24:06 PM »
Hi Chip,
Even this time no luck.
I've added the DLL you posted to the MACH3 directory but it give's the same results. a instant crash when i hit the button "Create offset"
See my list of DLL-files from the MACH3 directory
Piet
ukkie12342000
7
Re: Lazycam Crash
Reply #8 on:
June 20, 2007, 12:06:53 AM »
Hi Chip
This problem is solved.
With the latest version of Lazycam that now available online it crashes no more on offset's
Piet
Print
Pages:
1
Go Up
« previous
next »
