Hello Guest it is September 28, 2026, 10:35:38 PM
Author Topic: How do I home the ATC  (Read 8788 times)
« on: February 25, 2017, 04:17:04 AM »
Hi
How do I home my ATC?
It is an 8 tool ATC for Mach3 Turn.
Activate cylinder is M7
Stepper motor is A
The home switch for A axis motor is set at tool 0.
  •  9,374 9,374
Re: How do I home the ATC
« Reply #1 on: February 25, 2017, 06:43:01 AM »
There is more than one way but I would write a VB (Cypress Enable) routine which basically does the following…
Check the home switch and if activated then exit if not then index ATC.
Repeat the operation.
The routine could then be placed in a Macro and called from within Gcode and / or placed in a screen button and executed upon button click.
« Reply #2 on: February 26, 2017, 01:25:06 AM »
Thank you Tweakie
Will this work?
'ATC Home
Code("M7")         'Unlock tool changer turret
Sleep(1000)               'Wait to unlock
SingleVerify(3)         'Home A axis, 3 = A axis
Sleep(20000)         'Wait for some time
Code("M9")       'Lock tool changer turret
Sleep(1000)               'Allow to lock
Then I put it into the macro folder, but how do I assigne a G code or buttom?
Gaute
  •  9,374 9,374
« Reply #3 on: February 26, 2017, 02:41:42 AM »
Hi Gaute,
The code required is Cypress Enable, which is a variation of VB so you need to make some alterations to your proposed code for it to work.
The Mach3 Scripter  (Operator / VB Script Editor) should help you compile suitable code and hopefully it will flag any errors etc.
The following documents may be of assistance to you :
http://www.machsupport.com/wp-content/uploads/2013/02/Mach3_V3.x_Macro_Prog_Ref.pdf
http://www.machsupport.com/wp-content/uploads/2013/02/VBScript_Commands.pdf
http://www.machsupport.com/forum/index.php?action=dlattach;topic=9312.0;attach=6986
http://www.machsupport.com/forum/index.php?action=dlattach;topic=11056.0;attach=14194
http://www.machsupport.com/forum/index.php?action=dlattach;topic=11061.0;attach=14193
