Hello Guest it is October 22, 2026, 08:41:15 PM
Author Topic: Can I safely reinstall mach4hobby?  (Read 6285 times)
« on: February 20, 2017, 06:48:27 PM »
I may have screwed it up.  Do I have to worry about ly license files if I just reinstall over the top of my last install?
Re: Can I safely reinstall mach4hobby?
« Reply #1 on: February 20, 2017, 07:19:00 PM »
If you are installing on the same PC and have not changed the hard disk
or the version of operating system, then your PCID should not have
changed. You will need to re-apply your license after Mach4 is reinstalled,
but you would use the same license file.
You can use Help > About to look at your PCID after the install and can
check it against the one shown in your license file to see if it changed.
If by chance it did change, you will need to log onto the license server
at MachSupport.com and use the license maintenance function to make
a new license file.
If your license file was supplied by the seller where you got Mach4 and
you do not have an account on the license server, you will need to ask
for help from the original seller of the Mach4 software.
Steve Stallings
www.PMDX.com
