Hello Guest it is October 23, 2026, 01:08:50 PM
Author Topic: Simulate Probe Strike  (Read 9992 times)
« on: February 20, 2017, 02:48:47 PM »
I am converting my Mach3 lathe probe script to Mach4.  I want to simulate a probe strike as I rewrite this.
I have tried adding a button to the screen and writing scripts for the down and up key presses to change the state to on and off.  My code is:
local inst=mc.mcGetInstance()
local hSig=mc.mcSignalGetHandle(inst,ISIG_PROBE)
       mc.mcSignalSetState(hSig,1)
and
       mc.mcSignalSetState(hSig,0)
What should I be doing since this doesn't work?
TIA
RT
RT
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Simulate Probe Strike
« Reply #1 on: February 20, 2017, 03:58:29 PM »
You are missing the mc in front of ISIG_PROBE
Code: [Select]
local hSig=mc.mcSignalGetHandle(inst,mc.ISIG_PROBE)
DazTheGas
« Last Edit: February 20, 2017, 04:00:00 PM by DazTheGas »
« Reply #2 on: February 21, 2017, 09:50:23 AM »
Thanks Daz, I would have looked at that for 2 days before seeing that.
Offline SSPW
  •  26 26
« Reply #3 on: April 19, 2017, 02:21:12 PM »
I wanted to same thing! i have button configured. In diagnostics and logging the probe led and signal 161 are changing. But it has no effect on MACH probing in a clean mach4 install in demo mode.
« Reply #4 on: April 19, 2017, 03:15:55 PM »
My appologies if I misunderstand what you are aiming to do, but the hardware probe input would normally be recognised and the axis position latched by  the controller. You should not expect the controller to do this in response to your changing the probe signal within Mach4. This is certainly the case with my CS Labs controller, where a hardware edge is needed to halt a G31 sycle: a Mach4 signal change has no effect on G31.
Allan
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #5 on: April 19, 2017, 03:41:36 PM »
Simulating a probe strike was very helpfull in designing some routines I done in lua without actually having to use my machine as a gineapig.
DazTheGas
