Hello Guest it is October 21, 2026, 07:56:06 AM
Author Topic: homing macros not working after copying profile  (Read 8908 times)
« on: February 14, 2017, 10:56:26 AM »
Hi all
    im sure iv had this before but can not remember what the answer is.
 i have copied a profile (as i wanted to up the z axis speed)
  but when i then run that profile none of the homing buttons work
   everything else seems to be fine  the axis's move limit switches all ok  all the settings seem to have copied but   unable to home !!!!
      Please tell me what iv forgotten to do to make this work.
             thanks in advance guys
Re: homing macros not working after copying profile
« Reply #1 on: February 14, 2017, 01:54:09 PM »
Are you using a custom screen?
« Reply #2 on: February 15, 2017, 08:39:43 AM »
Thanks Gerry
sorted now
  I was using 2010 screen set and eventually remembered that you have to manually copy some of the macros "for some reason"
      Thanks for the memory jog  ;)
