Hello Guest it is October 21, 2026, 04:40:01 PM
Author Topic: Y&A Axes Move the Wrong Direction  (Read 13889 times)
Offline kolias
  •  1,165 1,165
« on: February 12, 2017, 06:29:11 PM »
When I stand in front of my cnc, X axis moves left / right, Z axis moves up/dn and the Y/A axes moves away from me or towards me (up/dn). To avoid confusion X axis moves with the right/left arrows, Z with the page up/dn arrows and Y&A with the up/dn arrows.
All is set correct except the Y&A. I have been playing with the Active Lows on the input signals and motor outputs plus clicking the Reverse in the Homing/Limits with no success. I can get Y&A to move up/dn the way I like it but then when at the MID screen I type G0Y1.0 the axes moves up (away from me) which is the negative way and I think it will create a conflict when I start a gcode.
In comparison the X axis when I type G0X1.0 modes to the right and Z when I type G0Z-1.0 moves down which both are correct
Any ideas what I do wrong?
Nicolas
Re: Y&A Axes Move the Wrong Direction
« Reply #1 on: February 12, 2017, 07:19:32 PM »
If you are having the axis jog incorrectly when using the keyboard, go to Config, System hotkeys, and setup the keys to go the way you want.
Mike
Offline kolias
  •  1,165 1,165
« Reply #2 on: February 12, 2017, 07:41:45 PM »
Never played with the hotkeys but I will do it and hopefully all will be fine
Nicolas
« Reply #3 on: February 14, 2017, 04:48:35 PM »
Let us know how you make out.
Mike
Offline kolias
  •  1,165 1,165
« Reply #4 on: February 15, 2017, 09:11:45 AM »
Looking at the Mach3 manual it says to be careful to assign keys because it may create confusion. I decided not to change any keys and look further on how to fix this problem. In another cnc I had I never had this problem and I’m surprised now why it happens. If I find no other solution I will change the wiring on Y&A axes.
Thanks Mike for your time
Nicolas
« Reply #5 on: February 15, 2017, 01:51:39 PM »
If X+ moves to the right, then Y+ SHOULD move away from you.
You can arbitrarily assign directions, it must follow the standard cartesian coordinate system.
Offline kolias
  •  1,165 1,165
« Reply #6 on: February 15, 2017, 04:12:26 PM »
It was my mistake Gerry all along, now all is fine. I was confusing the gcode's plus/minus direction. Sorry
Nicolas
« Reply #7 on: February 17, 2017, 03:45:41 PM »
At least you got it straightened out in the end.
Mike
Offline kolias
  •  1,165 1,165
« Reply #8 on: February 17, 2017, 05:15:05 PM »
Yes Mike, my apologies
Nicolas
