Hello Guest it is November 23, 2026, 09:39:53 PM
Author Topic: Homing and Limits  (Read 21969 times)
Homing and Limits
« on: February 12, 2017, 10:00:07 AM »
There's a million hits when I search for this but not a simple answer! I have single inductive proximities on each axis. Told Mach3 to use each signal (each on separate pin) as a combination home, limit+ and limit- trigger. When I 'ref all' machine homes and backs-off in all axes as it should but if I inadvertently jog in the wrong direction the 'limit' switch is re-triggered and all stops...as it should...but then Mach won't let me reset as it 'sees' a limit switch STILL triggered??? I would have thought that it would allow you to manually 'back-off' the limit switch in the opposite direction but until 'reset' is hit (which it won't accept) you can't. I'm sure I have something not set right as each time this happens I have to go into Ports and Pins and disable the X++ and X-- detection just to allow me to move off the limit switch! What am I doing wrong!! This can't be the normal operation of any controller as it ends up in a logical lock-up situation...'Limit switch hit therefore NOTHING moves, reset needed...Oh...you can't reset while a limit switch is STILL hit' therefore solid lock-up??
Tim
Pacer Cadet, guts gone, new stuff installed, sounds like a full string quartet in motion...
Offline kolias
  •  1,165 1,165
Re: Homing and Limits
« Reply #1 on: February 12, 2017, 10:18:21 AM »
Did you check the box on the Settings Menu "Auto Limits Override" ?
Nicolas
« Reply #2 on: February 12, 2017, 10:21:21 AM »
Hi Kolias..Not yet as I am trying to find a way where Mach allows you to move 'away' from the triggered limit but only stops you from barging any further 'into' the switch.
Tim
« Reply #3 on: February 12, 2017, 11:47:05 AM »
Mach3 is not that smart. Since you're using a single switch, Mach3 has no idea which direction to move.
« Reply #4 on: February 13, 2017, 05:03:09 AM »
Hi Ger,
Thing is there is a switch per axis and if Mach3 moves, say ++ and hits a limit switch then surely it is kids play in software for it to disallow further ++ movement and only allow -- movement??
Tim
« Reply #5 on: February 13, 2017, 06:14:35 AM »
That's not how it works, and since development stopped 5 years ago, it's not going to change.
« Reply #6 on: February 14, 2017, 02:45:54 AM »
 :-\ :-\...mmm..OK. Well I've changed a few things, set the soft limits before the physical switch limits, set the auto limits override and ditched having both + and - limits on the same input pin and although it's not perfect it doesn't get into the irreversible lock-up situation that it did before! Does Mach4 address the problem??
Offline Davek0974
  •  2,606 2,606
« Reply #7 on: February 14, 2017, 09:51:46 AM »
I don't know about Mach4 but once setup and working, limits with soft-limits in Mach3 is pretty bullet proof, I have three machines here all setup the same and all work just fine - I can jog into any soft-limit and it still allows me to jog off ok.
It must be a setting or construction/wiring issue.
Offline kolias
  •  1,165 1,165
« Reply #8 on: February 14, 2017, 10:00:07 AM »
I set my limits in Ports & Pins/Input Signals, at the bottom right of the screen there is a button "Automated Setup of Inputs". Mach3 will do all the work for you
Nicolas
« Reply #9 on: February 14, 2017, 10:26:14 AM »
Hi Guys,
Thanks for the replies but Dave...I can jog into and away from a soft limit like you can... but if I hit a full limit (as opposed to a soft limit) movement stops (correctly) but I can't reset to allow me to manually 'back-off' as the reset says 'no reset while a limit switch is active'.
I set all the pins manually with no issues but there does exist this anomaly in Mach3 that once on a full limit you can do nothing to get off it manually without going back into the program, altering a parameter, coming out the program, moving the axis OFF the limit, going back into the program, returning the parameters to normal and then carrying on! Mach3 is so comprehensive that I had imagined there would be a couple of lines of code that allowed you to jog AWAY from a hit limit switch with a jog button. I'm sure the coder had a reason to not include it...probably safety or something.
I'll live with it ;)
