Hello Guest it is October 20, 2026, 05:40:05 PM
Author Topic: Mach3 Leadshine MX4660 - Reconfiguration estop  (Read 12610 times)
« on: February 06, 2017, 10:34:16 AM »
Hi everyone, I have a Gryphon CNC and it was working great. I was using last Friday night and when I came back on Saturday I got this message "reconfiguration estop" and basically the machine is not working now.
I'll already check the power and everything is on so I think it's something related with the ports and pins configuration.
Any help or advice?
  •  9,374 9,374
Re: Mach3 Leadshine MX4660 - Reconfiguration estop
« Reply #1 on: February 07, 2017, 04:08:22 AM »
I am assuming you cannot get Mach3 out of Reset…
Check your actual EStop switch to make sure it is reset (closed circuit) and that it is connected correctly.
Try changing the Active State for EStop in Config. / Ports & Pins / Input Signals.
