Hello Guest it is November 22, 2026, 04:30:55 PM
Author Topic: z axis adjustment on milling machine  (Read 7893 times)
« on: February 05, 2017, 03:50:44 AM »
Gents
quick question on my milling machine i have home sensor on top of z-axis so at moment that is 0mm and then movement closer to bed is "x"+mm how to set 0mm to be fully down to bed and - max movement on top at home sensor ?
Re: z axis adjustment on milling machine
« Reply #1 on: February 05, 2017, 04:36:59 AM »
that is normal, machine co-ord zero at the top of Z travel. When you drive the Z axis done the machine co-ords are negative.
When you get to the surface that you wish to machine zero the Z axis work co-ords. Then a negative Z will take you below the surface ie
cutting and positive Z takes you above the surface.
