Hello Guest it is November 22, 2026, 04:13:17 PM
Author Topic: About the motors  (Read 9914 times)
About the motors
« on: February 05, 2017, 12:51:49 AM »
HI,l use 34hs9840 model motor.l want to know the maximum and minimum velocity per mm in motor calibration,l use mach 3.thanks
  •  9,378 9,378
Re: About the motors
« Reply #1 on: February 05, 2017, 01:48:46 AM »
Generally, increase the Velocity until the motor stalls then reduce the Velocity by 30%. The Acceleration should initially be set at 10% of the Velocity figure.
After that 'trial and error' may be used for tuning to obtain best, reliable, performance.
The Mach3 manual (Section 5 and 5.5 in particular) details the setting-up procedure  http://www.machsupport.com/help-learning/product-manuals/
« Reply #2 on: February 05, 2017, 01:53:16 AM »
guessing these are 34 size steppers about 900 ozin?
Steppers lose torque big time when running fast, at 1000 rpm they are likely to have on 5% of rated torque.
Probably wise to say that max speed is 500 rpm. If you use 5mm pitch ballscrews then max axis speed is 5 times 500=2500mm/min.
You can experiment but this should get you close enuf to start with.
« Reply #3 on: February 05, 2017, 08:02:50 AM »
The torque fall off is primarily due to back EMF reducing the current to the motors. Higher voltage drives and power supply make a big difference. My machine has 80 volt drives and a 68volt power supply. I am running a job right now at 3000 mm/m and slowed it down from 4000 only because there are lots of small details.
