Hello Guest it is November 22, 2026, 06:08:45 PM
Author Topic: Mach 3 Ports & Pins Settings for the Taig 5019 CR-ER  (Read 8032 times)
« on: January 29, 2017, 10:19:35 PM »
Recently purchased the New Taig 5019-CR-ER ball screw mill. My email program is an older OE and some files that were sent would not open. Would like to know the port & pins setting, etc and the motor output settings, input & output settings, that you have found satisfactory using the Mach 3 controller.  Any an all information, suggestions would be appreciated. Using XP3 with parallel port .... The Micro mill 2000 HD/LE controller...... inch settings needed for mach 3 .... 4 axes. Hope this helps!  Thank you very much! PM
