Hello Guest it is October 22, 2026, 07:54:52 PM
Author Topic: Stop/Reset scripts with and without Gcode  (Read 8004 times)
« on: January 28, 2017, 10:32:55 PM »
Hi All,
I've got myself tied up in knots. Over the last few days I've been helping Zuxztah to write code sufficient to control a VFD
over Modbus. Has been coming on pretty well but find myself out of my depth and the end.
Have got the Modbus link to work, have the scripts necessary for the CW and CCW buttons and associated spindle override to work.
The problem is how to stop the spindle under different conditions. From Gcode or MDI m5 works fine.
For the 'Stop' button I have the following:
Code: [Select]
Shutdown();
CycleStop();
For the 'Reset' button I have:
Code: [Select]
Shutdown();
mc.mcCntlReset(inst)
--mc.mcSpindleSetDirection(inst, 0)
mc.mcCntlSetLastError(inst, 'diagReset')
And the two functions in the screen load script:
Code: [Select]
--  Spindle Shutdown
function Shutdown();
    local inst=mc.mcGetInstance();
    mc.mcCntlGcodeExecuteWait(inst,"m5");
end;
-- Cycle Stop function.
function CycleStop()
    mc.mcSpindleSetDirection(inst, 0);
    mc.mcCntlSetLastError("Cycle Stopped");
    mc.mcCntlCycleStop(inst);
end
When I click the Reset button it appears to work, namely it calls m5 and therefore stops the spindle executes the mc.mcCntlReset(inst) statement
and as a diagnostic feature displays mc.mcCntlSetLastError(inst, 'diagReset').
When I click the Stop button it executes m5 and stops the spindle and appears to execute mc.mcCntlCycleStop but never displays
mc.mcCntlSetLastError("Cycle Stopped");.
Worse however if I have a Gcode program running and either Stop or Reset buttons are clicked the spindle does not stop and Mach4 crashes.
What am I misunderstanding?
What does mc.mcCntlCycleStop actually do?
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Stop/Reset scripts with and without Gcode
« Reply #1 on: January 29, 2017, 02:40:02 AM »
Is there anything missing from this line that may cause it to not work ;-)
DazTheGas
Offline dude1
  •  1,253 1,253
« Reply #2 on: January 29, 2017, 03:07:52 AM »
syntax is a pita
« Reply #3 on: January 29, 2017, 03:50:37 AM »
Hi Guys,
you're right, mc.mcCntlSetLastError() requires 'inst' as argument.
Other thing I found was:
mcScriptExecute() rather than mcCntrlGodeExecutWait() means that the m5 script does not have to compete with a running Gcode job.
Thanks again
