Hello Guest it is October 22, 2026, 05:36:38 PM
Author Topic: M6 Script not working  (Read 8165 times)
« on: January 27, 2017, 09:43:16 AM »
I am having an issue getting the M6 tool change to work when a "Tx M6" is called in my program. When my program calls for a tool change the code skips the tool change and moves on to the next operation using the same tool. Does anybody know what could be causing this? I have changed the m6() to M6() and that didn't do anything. The script is in the proper folder. I'm at a loss as to why this won't work. I have to enable M1 optional stop in order to make the machine allow for me to change my tools but this is not ideal for me. Any help would be appreciated.
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: M6 Script not working
« Reply #1 on: January 27, 2017, 09:55:36 AM »
Keep you macro names in lowercase and look in the mach4 configuration/tools, you will find an option for m6 T is next tool or tool in use.
DazTheGas
« Reply #2 on: January 27, 2017, 12:21:46 PM »
Ok I will give that a try, Thank you.
« Reply #3 on: January 29, 2017, 01:33:42 PM »
That worked, my tool changes work as expected now. Thank you for your help.
