Hello Guest it is November 22, 2026, 05:08:39 PM
Author Topic: Home/Limit referencing.  (Read 16206 times)
Offline Leeway
  •  149 149
    • LeeWay Workshop, LLC
« on: March 17, 2006, 12:18:17 PM »
Hey fellas.
Finally had time to get my switches wired up.
I currently have the X-- and X home wired to the same switch. I am aware how to use the soft limits, but how do I get the machine to pull off of the switch automatically to a certain point? I am not sure of the accuracy of the switch, but its the best way I have right now of setting zero at the same place on the machine every time. My Y is setup the same. The X++ and Y++ limits are shared. I would just like it to pull off too. I know I can set these to be able to jog off it. I was just wanting a way to reference.
Thanks in advance.
Lee
Re: Home/Limit referencing.
« Reply #1 on: March 17, 2006, 06:33:36 PM »
Check this out and see if it helps...
http://machsupport.com/forum/index.php?topic=314.0
www.newfangledsolutions.com
www.machsupport.com
Offline Leeway
  •  149 149
« Reply #2 on: March 18, 2006, 07:35:16 AM »
It most certainly was helpful. Thanks a bunch, Brian.
Lee
