Hello Guest it is October 20, 2026, 07:45:17 PM
Author Topic: Motor on CNC not running but running onscreen in MACH3  (Read 8357 times)
« on: January 23, 2017, 02:19:30 PM »
Hello all
Started my CNC the other day after a few years of "rest".  I started with a simple sign using the WRITE Wizard and i got a problem i know I had a few years ago.  The G-Code looks OK but when I run it the router stops even if it shows on screen that its moving.  This happens for a single line but as you can imagine it trows off the whole job.  Can you point me to where I should look?
Dom
  •  9,374 9,374
Re: Motor on CNC not running but running onscreen in MACH3
« Reply #1 on: January 24, 2017, 12:20:40 AM »
Is the stepper motor for the axis that has quit moving making a whining noise ?
