Hello
Guest
it is
November 23, 2026, 05:08:38 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
How many steps should I use?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: How many steps should I use? (Read 9776 times)
Cartierusm
354
on:
January 21, 2017, 09:38:25 PM »
I'm almost finished with my mori sl1 retrofit. My Servos are factory set at 2000 steps per revolution. I can change it to upwards of 16,000 steps per revolutions. It's a 3 to 1 gear reduction. Not sure what pitch my ball screws are. So what should I use as steps per revolution? I know how to set them up in Mach.
Logged
Davek0974
2,606
Re: How many steps should I use?
Reply #1 on:
January 22, 2017, 02:29:36 AM »
If you don't know the screw pitch you will have to either measure it by placing a dial indicator suitably and turning the screw once or use Mach 3 and carefully test by entering a distance and measuring the resulting move.
Mach3 has an auto-calibrate feature on one of its screens - this might help but i would start by only entering small distances.
Logged
ger21
6,295
Reply #2 on:
January 22, 2017, 05:55:54 AM »
If they are adjustable, then they are using electronic gearing. You want to sett hem to as high a value as you can, but you mat be limited by the pulse rate of the PC or motion controller that you are using.
Logged
Cartierusm
354
Reply #3 on:
January 22, 2017, 11:31:58 AM »
@ger21, yeah that's what I figured. I'm using a Pokeys 57E motion controller. I've always used stepper with direct drive and used 10 micro steps, but since I'm using servos on professional machine I was wondering if I should go higher.
Logged
Print
Pages:
1
Go Up
« previous
next »
