Hello Guest it is November 01, 2026, 10:05:44 AM
Author Topic: DXF from turbocad  (Read 58483 times)
DXF from turbocad
« on: March 17, 2006, 04:31:35 AM »
Hi
Just loaded up easy cam to try.
I currently use sheetcam with Turbocad generated DXF files . I have no problems with the DXF file format in sheetcam but every time I try and load the same files into lazycam I get the microsft porgramme has encounterd an error message. ???
Any ideas
Iain
Re: DXF from turbocad
« Reply #1 on: March 17, 2006, 08:23:28 AM »
Could you please post an example DXF file?
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: March 17, 2006, 11:05:06 AM »
Hi
Here is an example that opens fine in Sheetcam
« Reply #3 on: March 17, 2006, 12:10:46 PM »
Do you have mach 3 installed? and in the default directory.
Thats what I was having untill i installed mach3
Jon
« Reply #4 on: March 17, 2006, 12:17:32 PM »
Thanks that was the problem ..wrong directory for Mach 3 ::)
Iain
