Hello Guest it is November 13, 2026, 12:04:01 PM
Author Topic: Mach 3 Auto Z setting not working.  (Read 10477 times)
« on: January 04, 2017, 09:14:44 AM »
Had to reinstall Mach 3. Now Auto Z setting not working.
Re: Mach 3 Auto Z setting not working.
« Reply #1 on: January 04, 2017, 07:31:02 PM »
There is no Auto Zero function in Mach3, you have to add the macro code to the button yourself.
So, if you had it working, the reinstall removed it.
« Reply #2 on: January 05, 2017, 06:10:39 AM »
Ok can u walk me through that or give me some steps
« Reply #3 on: January 05, 2017, 06:23:03 AM »
If you have the macro, go to Operator > Edit Button Script. Click the button, and paste the macro into the editor, then File > Save.
« Reply #4 on: January 05, 2017, 08:54:09 AM »
This is what was in there when I checked the macro.
« Reply #5 on: January 05, 2017, 09:07:40 AM »
I'm guessing the switch that controls the home to z is stuck to active and needs to be replaced. When I go to zero all
In top left ref z nothing happens. Go to Cnc and press and hold button and ref z and it will move the head.
