Hello Guest it is November 13, 2026, 09:49:00 PM
Author Topic: Auto zero tool does not work!!  (Read 16482 times)
« on: December 27, 2016, 06:46:30 PM »
I am not sure if I am just not understanding this. I got the probe to work when I touch them together I can see the light working just fine. The problem I am having is when I set the macro and hit auto tool zero it goes in the wrong direction. I set the z- to reverse in the home and limit's. Then it went in the right direction but it never stopped when it hit the plate. I am not sure if the script is just bad or just me not doing this correctly.
I might be missing something here. I did go on youtube got some great info but still does not work right.
Here is a copy of the script I am using.
'Rem   Probe Down by PEU (Based on Erniebro Work)
FeedCurrent = GetOemDRO(818)    'Get the current settings
ZCurrent = GetDro(2)
Code "G4 P1"         'Pause 1 second to give time to position probe plate
Code "F100"         'slow feed rate to 100 MM/MIN
GageH = GetOEMDRO (1002)
ZCurrent = GetOemDro(802)
GageH = GetUserDRO(1152)
ZNew = ZCurrent - 30      'probe down 20 mm
Code "G31 Z" &ZNew
While IsMoving()
Wend
Call SetDro (2,GageH)
FinalMove = GageH * 1
Code  "G0 Z" &FinalMove
Code  "G0 Z" &20
Code "F" &FeedCurrent        'restore starting feed rate
Any help would be great thank you
Re: Auto zero tool does not work!!
« Reply #1 on: December 27, 2016, 07:07:29 PM »
Before you did this, was it moving in the correct direction during jogging and when running code?
There could be a lot of reasons why the probing is going in the wrong direction.
Is your machine set up in mm's? Because the macro is in mm's.
When you run the macro, is the machine in G90 or G91 mode?
It's possible that noise is triggering the probe input as soon as you start the macro, and what you're seeing is the machine doing the final retract move.
« Reply #2 on: December 27, 2016, 08:06:52 PM »
Hi Gerry, thanks for your reply.
Before I did this, when hitting Z-, the Z goes all the way up; with Z+, Z axis goes all the way done.
The machine is set up in mm' and I am not so sure how to find out about G90 or G91 mode, but I think it's a G90 mode machine. How would I determine if it's a G90 or G91?
« Reply #3 on: December 27, 2016, 08:23:20 PM »
Btw, I was just looking into your website, seems you have a program called 2010 Screenset that would be able to set Z auto zero and ready to run. I just get into learning the CNC and Mach 3, absolutely new to everything, would you suggest 2010 Screenset program for my problem or it's for more advanced user?
« Reply #4 on: December 28, 2016, 07:02:42 AM »
First thing you need to do, is go to the Diagnostics page, and see if the Digitize LED light up when you touch the plate to the tool.
You want to make sure that your probe input is working before you attempt to use the 2010 Screenset.
It's not really for advanced user's, but you should have decent knowledge of Mach3 before you use it, or it may cause some confusion.
« Reply #5 on: December 28, 2016, 12:38:43 PM »
Thanks for taking the time to get back to me. Yes it does light up when I touch the plate.
