Hello Guest it is November 13, 2026, 11:56:01 AM
Author Topic: from k-cam to mach 3 some issues  (Read 7189 times)
« on: December 26, 2016, 04:56:52 PM »
hello, im new here. i have a  cnc router working thru parallel port and came with kcam
now, i prefer to use mach 3 and sheet cam (or vectris since it seems much more robust, so i managed to configure the ports for X Y Z  and switches for spindle flood (really lantern and exrtactor) etc. but still works somehow weird
with k cam moves  quite well smooth but when go to mach3 seems weird. i tried to adjust speed and step but does not sound the same
here is the caleery for comparison https://goo.gl/photos/K13XHRhsBWeKGhcM7
the first is the config from the KCAM
the second is the config in MACH3d
everything is in metric system
the steps are wel i chequed against a ruler seems to be good 10 mm in the ruler = 10 mm in the machine
but the speed and ramp and general sound is not the same i fear to brake the motors or something.
lastly in the second picture i increased speed values because if i puut the same i got in kcam is toooo slow
thanks in advance
can you help me please?
