Hello Guest it is November 24, 2026, 08:35:16 PM
Author Topic: sheetcame/mach3 issue  (Read 7188 times)
« on: December 19, 2016, 09:43:55 AM »
hey all ive been running cut2d/sheetcam/mach3 for 3 years now flawlessly, and now sheetcam is giving me weird codes when i check them in notepad. This is causing Mach3 to just run through the whole code without moving at all. any ideas? thanks.
N0010 (Filename: circle.tap)
N0020 (Post processor: Mach3 plasma.scpost)
N0030 (Date: 16/12/2016)
N0040 G20 (Units: Inches)
N0050 G53 G90 G91.1 G40
N0060 F1
N0070 S500
N0080 (Part: circle)
N0090 M05 M30
this is the code sequence im getting from every file i import and export from sheetcam.
  •  9,378 9,378
Re: sheetcame/mach3 issue
« Reply #1 on: December 20, 2016, 01:01:07 AM »
