Hello Guest it is October 13, 2026, 02:56:24 AM
Author Topic: Understanding Lua  (Read 33461 times)
Re: Understanding Lua
« Reply #10 on: December 19, 2016, 04:07:39 PM »
I have it working in a screen button .
Now I don't know how to get it to work in the m110 macro  m110 in mdi causes an error expecting a number
Tired to make a file load.modules.mcs in the macros directory of the profile containing
 local profile = mc.mcProfileGetName(inst)
    local path = mc.mcCntlGetMachDir(inst)
    package.path = path .. "\\Profiles\\" .. profile .. "\\Modules\\?.lua;" .. path .. "\\Modules\\?.lua;"
package.loaded.mcUserScript = nil
us = require "mcUserScript"
« Reply #11 on: December 19, 2016, 04:12:50 PM »
Where are you defining the inst variable your using in the first 2 calls?
inst = mc.mcGetInstance()
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #12 on: December 19, 2016, 04:13:55 PM »
Change the filename to  load_modules.mcs
DazTheGas
« Reply #13 on: December 19, 2016, 04:35:10 PM »
Changed file to load_modules.mcs
Added inst = mc.mcGetInstance() to load_modules.mcs
Still not running with m110 in MDI
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #14 on: December 19, 2016, 05:28:39 PM »
This is where I have place files
C:\Mach4Hobby\Modules\mcUserScript.mcs
Code: [Select]
local mcUserScript = {}
function mcUserScript.UserMessage(Message)
if (Message == nil) then --No message was passed
Message = "No message passed" --If no message is passed this will be the default message
end
wx.wxMessageBox(Message)
end
return mcUserScript -- Module End
both the m110.mcs and load_modules.mcs goes in your profiles own macro directory
load_modules.mcs
Code: [Select]
m110.mcs
Code: [Select]
function m110()
us.UserMessage("This is my message from m110")
  end
if (mc.mcInEditor() == 1) then
 m110()
end
This is working within the mdi no problem but still debugging why its not working when called from within gcode, my bet is its something to do with the messagebox not being able to show in the gui from gcode. when running gcode its run within another lua instance that does not have access to the lua instance that is within the gui.
DazTheGas
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #15 on: December 19, 2016, 05:42:57 PM »
Yep changing the code to below without the messagebox worked fine using mc.mcCntlSetLastError(inst,Message) instead
Code: [Select]
end
--wx.wxMessageBox(Message)
end
with this now working it should give you something to play with ;-)
DazTheGas
« Reply #16 on: December 19, 2016, 06:45:32 PM »
Thanks, it works for me.
I appreciate the follow through.  Learning!
Keith
« Reply #17 on: December 19, 2016, 06:49:58 PM »
Only difference is
C:\Mach4Hobby\Modules\mcUserScript.mcs should be
C:\Mach4Hobby\Modules\mcUserScript.lua ??
Keith ???
« Reply #18 on: December 19, 2016, 07:01:54 PM »
When I create a gcode file with one line m110 it bombs out the gui?
« Reply #19 on: December 19, 2016, 07:05:47 PM »
Gcode FILE  with
G0 X0Y0
M110
G0 X1Y0
works fine
