Hello Guest it is November 13, 2026, 11:00:33 AM
Author Topic: No communication between computer and controller box.  (Read 61170 times)
Re: No communication between computer and controller box.
« Reply #40 on: December 20, 2016, 11:34:42 AM »
Hi Craig,Tweakie
made those changes  5 but no change. Mach3 shows dro working when left and right buttons pushed. no motor movement.
I think now is the time to take the BOB out and recheck all sodier joints and components. I will do that the rest of the day If I replace it to no avail, I will buy another one.
« Last Edit: December 20, 2016, 11:40:25 AM by captainleeward »
  •  9,377 9,377
« Reply #41 on: December 21, 2016, 01:11:40 AM »
Looking at you .xml file…
The Step & Direction pin allocations in Motor Outputs do not match the .pdf document (manual) you have attached in post #22.
If you are using Estop then you need to allocate a Port# in Input Signals.
In Motor Tuning I suggest you change the Step Pulse and Dir. Pulse  to 2uS.
Perhaps also try changing the Step Low Active State in Motor Outputs (from cross to tick) and see if that makes any difference.
« Reply #42 on: December 21, 2016, 08:35:35 AM »
Hello Tweakie,
Not sure what you want me to do here I have them set as per the manual 2/3 4/5 6/7 ..Ward
« Last Edit: December 21, 2016, 08:37:53 AM by captainleeward »
  •  9,377 9,377
« Reply #43 on: December 21, 2016, 09:13:43 AM »
Unless something has gone screwy my end the .xml file you posted shows...
X Step 2
X Dir 6
Y Step 3
Y Dir 7
Z Step 4
Z Dir 8
« Reply #44 on: December 21, 2016, 10:18:01 AM »
Hello Tweakie,  Will cherck that ASAP.   Thanks  Ward.
« Reply #45 on: December 21, 2016, 03:26:29 PM »
I need a few days to investigate this matter,,  Ward.
« Reply #46 on: December 21, 2016, 07:06:52 PM »
Fellas, I have sent the BOB back to the seller to have it checked out before continuing this fix so please bare with me for a week or so  Thanks you guys....:O)   Ward
