Hello Guest it is November 13, 2026, 09:35:38 AM
Author Topic: subroutine problems  (Read 10109 times)
subroutine problems
« on: November 25, 2016, 05:13:39 PM »
I'm hoping someone can help me with a subroutine.  I never use them, but now that I have built a plasma table, I can see that I may be using them a lot in the future.
I'm running Mach 3 on winxp.  For some reason, it errors out if I put an M99 at the end of my subroutine, but doesn't if I use M17.  At any rate, it is supposed to be cutting two rectangles.  It only cuts one and I can't figure out why.
Here's my code with comments on what I think is happening.  Hopefully someone can correct me.
N001 O0001 (MAIN PROGRAM)
N002 G90 (ABSOLUTE POSITIONING MODE)
N003 G0X0Y0Z0 (RAPID POSITION)
N004 G01 X.875 Y.500 F83 (FEED AT 83 IPM)
N005 M98 P0002 (CALL SUBROUTINE 2)
N006 G0 X2.875 (RAPID POSITION)
N007 M98 P0002 (CALL SUBROUTINE 2)
N008 M99
O0002 (SUBROUTINE 2)
G91 (INCREMENTAL POSITIONING MODE)
M3 (TORCH ON)
G04 P1 (DWELL FOR 1 SECOND)
G01 Y-.043 F83 (FEED AT 83 IPM)
X-.060 (FEED AT 83 IPM)
Y3.043 (FEED AT 83 IPM)
X.120 (FEED AT 83 IPM)
Y-3.043 (FEED AT 83 IPM)
Y.043 (FEED AT 83 IPM)
Z1 (FEED AT 83 IPM)
M5 (TORCH OFF)
M17
Re: subroutine problems
« Reply #1 on: November 26, 2016, 10:06:03 AM »
Not an expert but:
at N008
N008 M30
then at end of sub
M99
Also, at every sub call I add L1 or however many loops to be called
HTH
« Reply #2 on: November 26, 2016, 04:43:00 PM »
Thanks for the help!
Here's my modified code:
M99
N008 M30
M3 (TORCH ON)
Z1 (FEED AT 83 IPM)
M5 (TORCH OFF)
M99
When I tried to run it, it gives me the following error:
"Return called with no sub in effect...looping"
Thoughts?
« Reply #3 on: November 26, 2016, 04:59:09 PM »
try:
N008 M30
M3 (TORCH ON)
Z1 (FEED AT 83 IPM)
M5 (TORCH OFF)
M99
« Reply #4 on: November 26, 2016, 09:50:29 PM »
That fixed it.  Had an extra M99 in there for some reason.  Thanks for the help!
