Hello Guest it is November 13, 2026, 09:35:20 AM
Author Topic: Problem About CNC with Mach3  (Read 8945 times)
« on: November 17, 2016, 07:22:21 PM »
Hello, im new in this forum, I write because I have a problem with my machine.
My machine worked well for several years, I stopped working a few weeks and after that presented a problem. the axes move perfectly, everything responds well, but when I load a file or I turn on the spindle the program sends a message: "too slow for pulley off", after that the software crash. I need to restart the computer to be able to connect again. I read several topics about this and I edit the pulley, and speeds but it does not work, after that the message change but it is the same, the software crash and i need to restart the machine and te computer.
i already changed the usb cable, reinstall the software and updated the drivers but does not work. I need help please.
I attached a photos of the second message, my interface and the board of my machine.
  •  9,377 9,377
Re: Problem About CNC with Mach3
« Reply #1 on: November 18, 2016, 12:47:42 AM »
Could you attach your .xml file. It is located in your Mach3 folder and named <your profile>.xml
(Copy the file to the desktop then rename it to sierradx.xml and use the Post / Additional Options to attach).
« Reply #2 on: November 23, 2016, 11:16:21 PM »
Ok I attach, thanks
sierradx55
