Hello
Guest
it is
November 17, 2026, 02:29:08 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach & Multi Tool Head
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach & Multi Tool Head (Read 10441 times)
Azrael
51
on:
June 03, 2007, 06:30:49 AM »
I have to retrofit some old Biese Rover 7 which has boring head with 7 tool holders. These holders are mounted on the head and are pulled down/up by pneumatics via 7 control signals. I was wondering What is the best option for control this function by Mach3. Is there possibility to define tool change macro so it can output BCD Code to Outputs #4-6. Then I could build BCD to 7 segment decoder and so on, control 7 tools.
The second question is for feed override button. I have reed that there is possibility of connecting encoder directly to LPT port, and enabling this function?
Logged
Brian Barker
3,860
Re: Mach & Multi Tool Head
Reply #1 on:
June 03, 2007, 04:45:10 PM »
The best way to do the FRO in your case is to use a ModIO . this will also giveyou the IO that you need for this project
Yes you can write a macro in the M6 to change tools and set the offsets... there are a few guys that will write the code for you for a $$$ and if they can't do it I can have a look at it... OR you can post here and we will teach you a bit of VB (not much fun but gives you the power
Hope that helps
Brian
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Azrael
51
Reply #2 on:
June 03, 2007, 04:49:53 PM »
Thanks Brian.
I would like to play a little bit with VB, as i am closed to C++ and assembler, so i think that it wouldn't be a problem. ModIO is my definite choice, but i have to do in next few days, and w/o it this time.
Logged
Print
Pages:
1
Go Up
« previous
next »
