Hello Guest it is October 24, 2026, 07:08:23 PM
Author Topic: Mach4 4K Monitor Support  (Read 11717 times)
« on: October 31, 2016, 05:24:45 PM »
I'm completely stuck as how to use my new CNC machine. I have a WinXP and a Win7 Desktop that have been complete garbage, reinstalled windows a few times, etc. Nothing. So I grabbed my new Dell XPS 15 with the 4k display, and Mach4 works beautifully, except I can't finish my setup because I can't resize any of the columns or text. I've tried every display workaround imagineable, including editing the registry like I do on some other programs that don't scale properly.
Any idea what it takes to fix this? I can't read half the labels on inputs/outputs and settings.
See attached pictures for details.
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Mach4 4K Monitor Support
« Reply #1 on: October 31, 2016, 05:49:59 PM »
Can you not just resize the columns with the mouse, run your cursor accross the headers and the mouse should change??
DazTheGas
« Reply #2 on: October 31, 2016, 06:23:34 PM »
Nope, first column is not width configurable. I wish it were that easy.
« Reply #3 on: October 31, 2016, 08:34:47 PM »
Change your font size in windows to 100%
Hi res monitors can cause a lot of issues, because you often need to run larger font sizes, and it can be difficult to program for them.
« Reply #4 on: October 31, 2016, 09:59:14 PM »
Yeah that works, but not in reality. The text is like 800 micrometers tall and is barely legible a couple inches from the screen.  I think I can make it work for initial setup at least.
« Reply #5 on: November 01, 2016, 08:23:48 AM »
Well, I doubt that they are going to rewrite everything to support larger fonts. It can be a LOT of work, and is difficult to get to work in all situations.
As I said, this is a problem with a lot of programs.
« Reply #6 on: November 06, 2016, 06:43:02 AM »
I have 2 monitors, 32", and 2560x1200 resolution on both, via displayport.
Win 7 64 bit.
No issues.
Nvidia Quadro 2000, industrial graphics workstation, my main machine.
You can probably fix it via windows or graphics drivers font settings.
Yes its a hack, but..
