Hello Guest it is November 01, 2026, 10:13:10 AM
Author Topic: Lcam not re-importing drill holes from .tap file  (Read 10185 times)
Offline Psad
  •  82 82
« on: June 02, 2007, 10:38:27 AM »
Art there is still an issue with LC not doing a reverse import.
Problem is I have a part that i've done all the work on in lcam.  Including changing a lot of machine holes to a drill drill holes on a separate drill layer.  I next export it to Mach3 (.tap) and find some problem.  now comes the problem, when i bring the tap file ("Load Current mach file..")  back into LCAM it does not import the drill layer holes, completely missing.  So now i have to start over from scratch.  No i did not save the original file to "save lcam project".  don't need to do it very often and i always forget.
Am i doing somehting wrong or is there a bug.
Re: Lcam not re-importing drill holes from .tap file
« Reply #1 on: June 02, 2007, 07:53:07 PM »
I think that is a bug.. Don't think we ever added it :)
www.newfangledsolutions.com
www.machsupport.com
Offline Psad
  •  82 82
« Reply #2 on: June 03, 2007, 11:06:02 AM »
pleas stick it on the list.  short list i hope
