Hello Guest it is November 01, 2026, 12:19:04 PM
Author Topic: text engraving  (Read 23765 times)
homecockpitbuilder
text engraving
« on: June 02, 2007, 09:29:00 AM »
Hello,
How far is the devolepment for text engrave with the new lazycam?
I now its working in the old one but get a lot of problems with it.
Bas
Re: text engraving
« Reply #1 on: June 02, 2007, 07:46:13 PM »
There is all new code ... it "should" work fine...
www.newfangledsolutions.com
www.machsupport.com
homecockpitbuilder
Re: text engraving
« Reply #2 on: June 03, 2007, 06:36:06 AM »
Strange, Can someone explain howto inport a autocad 2007 dxf file with a futura bold text  in lazycam? When i do this it says that there are no line's in it?
Bas
Re: text engraving
« Reply #3 on: June 03, 2007, 04:39:57 PM »
You will need to explode the text into line segments... that should do it :)
www.machsupport.com
homecockpitbuilder
Re: text engraving
« Reply #4 on: June 13, 2007, 02:41:19 PM »
Ok now i have a text. Now my next question is:
 How can i let only the inner cut? The text must be engraved with only one line Now it's going around the letter.
regards:
Bas
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: text engraving
« Reply #5 on: June 15, 2007, 10:36:54 AM »
You need to use a single line font or pocket the font out.
Graham.
homecockpitbuilder
Re: text engraving
« Reply #6 on: June 15, 2007, 03:35:55 PM »
Hello Graham,
Can you tel me how to pocket the font out?
Regards Bas
Re: text engraving
« Reply #7 on: June 25, 2007, 08:09:03 PM »
To Pocket the text you need to have a box around the text. Select the box and tell Lcam Pro to pocket out the box and it will know that there is text in the box and pocket around it .
Hope that helps
Brian
www.machsupport.com
Re: text engraving
« Reply #8 on: June 30, 2007, 03:55:12 PM »
Homecockpitbuilder,
Did you manage to packet your text.
I have been struggling to do this with the Trinity font but no success yet.
tmsmith
Re: text engraving
« Reply #9 on: April 06, 2008, 01:42:02 AM »
I also have been having no success with pocketing Text.
For example: when the letter "A" is dragged into a rectangle, and then pocketing is performed, the outer line of the "A" is left as an island but the inner part of the letter is also engraved. No matter how you try, the inner part cannot be separated (ungrouped?) from the outer part of the letter and pocketed on its own. The guys writing this program are doing a great job so maybe this bug can be fixed in a later revision of LC.
Bruce
« Last Edit: April 06, 2008, 01:48:05 AM by MachBruce »
