Hello Guest it is November 13, 2026, 07:43:51 PM
Author Topic: Pokeys57CNC Driver Connection  (Read 19352 times)
Offline Blaat
  •  10 10
« on: October 30, 2016, 02:05:10 PM »
Hi all
I'm trying to get my steppers running
This is what I did
I have a Pokeys57CNC board
steppers with 4 wires
DM542A drivers from Longsmotor
I can see my Pokeys board in Mach3.
But the steppers are not running yet.
I think I did something wrong with the wiring from pokeys to driver
Pul + (+5V) to the Pokeys 5V motor connector
Pul - to STEP pin on the Pokeys motor connector
Dir + (+5V) to the Pokeys 5V motor connector
Dir - to DIR pin on Pokeys motor connector
I didn't connect the ENBL pins
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys57CNC Driver Connection
« Reply #1 on: October 30, 2016, 02:54:51 PM »
I would strongly suggest to wire PUL+ and DIR+ to step and dir pins on the motor connector and PUL-/DIR- to GND on the motor connector.
Is motor hard (or impossible) to turn by hand?
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Offline Blaat
  •  10 10
« Reply #2 on: October 30, 2016, 04:46:16 PM »
Thanks! It runs!
Mach would throw a 'emergency button error', but I had to revert the stop settings in the pokeys configuration.
Only 'problem' now is that the stepper turns, but it turns only to one side, doesn't matter if I press the < or > arrow on the keyboard.
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: October 30, 2016, 11:55:00 PM »
Check the DIR+ and DIR- connections.
Offline Blaat
  •  10 10
« Reply #4 on: October 31, 2016, 02:40:05 AM »
DIR+ (driver) is connected to DIR pin (motor connector)
DIR- (driver) is connected to GND pin (motor connector). DIR- and PULL- are connected with the same cable to ground on the Pokeys Motor Connector
Offline Blaat
  •  10 10
« Reply #5 on: October 31, 2016, 07:09:08 AM »
found it, made a wiring fault from driver to pokeys.
working fine now :)
