Hello Guest it is November 04, 2026, 01:59:26 AM
Author Topic: Bentley logo G codes help  (Read 49469 times)
« on: October 29, 2016, 11:49:36 AM »
Hi friends! i just came cross this forum and saw how helpful this community is.
I would like to ask for your help . Can anyone help me with G codes for Bentley logo , i will be doing it on an aluminum sheet ( dimension  400mm x 350mm , 1mm depth )
i have attached the logo and example of the final cut out/ the result of the cut
If anyone can help me that will be so great !!  Thank oyu
« Last Edit: October 29, 2016, 11:51:43 AM by tothemaking »
Re: Bentley logo G codes help
« Reply #1 on: November 14, 2016, 11:37:39 AM »
If i put PDF file can someone help with the g codes?
  •  9,375 9,375
« Reply #2 on: November 15, 2016, 01:41:57 AM »
I am not sure if this helps you or not …
For a 2D part, starting out with a logo in .jpg form I have converted it to a .dxf then created the Gcode for an engraving toolpath of the outline of the image and attached the relevant files.
Creation of a 3D (2.5D) part requires quite a lot more work - you either find (on the net) or create a depth map image of your logo then generate a 3D toolpath from that image.
« Reply #3 on: November 15, 2016, 02:17:47 AM »
Thank you!
The G codes in my book look little different they are like ( G90 , G01, G12 etc)
I tried to change the autocad drawing into dxf and then use cambam to get gcodes but it didn't work for me :/  , i dont know why
I attached them just in case someone will be able to help me with it
« Reply #4 on: November 15, 2016, 02:20:42 AM »
this is the pdf
and the dxf said its too big to attach :/ and when i try to open it on cambam it wont work .
« Last Edit: November 15, 2016, 02:22:43 AM by tothemaking »
  •  9,375 9,375
« Reply #5 on: November 15, 2016, 03:05:48 AM »
Zip then attach your .dxf (use a unique file name).
« Reply #6 on: November 15, 2016, 03:11:44 AM »
here
  •  9,375 9,375
« Reply #7 on: November 15, 2016, 03:22:23 AM »
Your .dxf file appears to be bad (corrupt) which is the reason you cannot open it in CamBam.
« Reply #8 on: November 15, 2016, 03:23:39 AM »
i did it while using the Autocad drawing that i made
is there away to fix it ?
  •  9,375 9,375
« Reply #9 on: November 15, 2016, 04:13:55 AM »
See if you can open your .dxf in AutoCad then save it as a different version .dxf
