Hello
Guest
it is
November 13, 2026, 10:39:07 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
General CNC Chat
Show"N"Tell ( What you have made with your CNC machine.)
some mach3 inlay work
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: some mach3 inlay work (Read 45409 times)
docltf
354
on:
June 01, 2007, 03:26:20 PM »
i used mach3 for the lay work,and some short parts.
bill
Logged
Brian Barker
3,860
Re: some mach3 inlay work
Reply #1 on:
June 01, 2007, 04:17:45 PM »
Nice! You make me want to work on the Lcam 4th axis code
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
ynneb
Reply #2 on:
June 03, 2007, 08:41:34 AM »
Brilliant.
Thanks for posting these fine works of craftmanship.
Logged
Chaoticone
5,624
Precision Chaos
Reply #3 on:
June 03, 2007, 09:22:07 PM »
Very Nice.
Logged
If you could see the things I have in my head, you would be laughing too.
W.Jansen
119
Reply #4 on:
April 12, 2008, 01:01:23 PM »
Hi Bill
Nice pieces did you make there.
I have a couple questions if I may.
What sort cutter did you use?
What size?
What feedrate?
What spindle speed?
How did you fix the inlays on your machine?
Did the wood not break on the edges and special on the topends?
Did the cutter turn against the feed direction or with the feed direction?
How thick was the inlay material?
I was thinking it was impossible to cut so extreme Small pieces.
Greetings:
Willem
Logged
docltf
354
Reply #5 on:
June 01, 2008, 01:49:58 PM »
Finished these two out last month.I put the brown one in my cue case and playing with it.too pretty to sell.put the red up forsale.
thanks bill
Logged
docltf
354
Reply #6 on:
June 01, 2008, 01:58:16 PM »
Forget to mention the differant wood.
Brown - birdseye maple,snakewood,yellow heart,cocobola,honduras rosewood,marblewood.
Red - birdseye maple,kingwood,pink ivory,white&black ebony,canary wood,bubinga,cherry diamond wood,tulip wood.
bill
Logged
Perfo
143
Reply #7 on:
July 19, 2008, 06:33:36 AM »
Do you cut these on a 4 axis mill ? Do you cut out the inserts as well ? Some v good work there and the accuracy seems spot on no obvious gaps anywhere.
Logged
docltf
354
Reply #8 on:
July 19, 2008, 10:28:16 AM »
Perfo
everythig is done with the same milling machine including the threaded pin using differant setups. no V carving used. the rubber bumper is from an outside source.
thanks bill
Logged
Perfo
143
Reply #9 on:
July 19, 2008, 11:02:41 AM »
Nice work. I'm not sure what v carving means I must be honest. I'm in the process of converting a mill and this is the kind of work I'd love to be able to do particularly copper/brass inlays in furniture and seeing your work mean at least I know it is possible to acheive the kind of results I'm after.
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
