Hello Guest it is October 21, 2026, 06:12:46 AM
Author Topic: Just when you think you are finally getting there....  (Read 42934 times)
Re: Just when you think you are finally getting there....
« Reply #20 on: November 28, 2016, 07:37:01 AM »
... centripetal acceleration....
Increase acceleration or decrease feedrate in the corners to get LEDs following error
Rob
Offline Davek0974
  •  2,606 2,606
« Reply #21 on: November 28, 2016, 07:39:57 AM »
As far as i know, its only SheetCam that can do whacky, useful things with feed-rates on demand.
I'll tune her up a notch and see what happens.
« Reply #22 on: November 28, 2016, 10:39:06 AM »
Onecnc XR7 has just added corner feedrate adjustment. Only helpful if you have the program of course.
Offline Davek0974
  •  2,606 2,606
« Reply #23 on: November 28, 2016, 12:26:09 PM »
I've doubled the acceleration to 700mm/s/s and checked the servo pid settings - following error did not alter and is still sub 250 on X&Y.
Air cutting the same code seems ok, you can feel it is a lot sharper when direction changes but will need to do some test cuts to verify.
Offline Davek0974
  •  2,606 2,606
« Reply #24 on: November 29, 2016, 11:47:19 AM »
Instant improvement, same code as before, same feeds etc just the increased acceleration in motor tuning.
Nice corners, no sign of rounding at all. :)
At least it now works up to 1000mm/min feed rates, no idea how much beyond that as i have no job that needs it.
« Reply #25 on: November 29, 2016, 12:51:46 PM »
Good news, never realised you originally had such slow acceleration but good its sorted now.
Offline Davek0974
  •  2,606 2,606
« Reply #26 on: November 29, 2016, 01:03:50 PM »
Seems so, without any firm figures i just plonked it somewhere it seemed happy at - seems it was ok at the lower speeds but then i upped the feed rate to book specs because i was seeing premature tool wear and thats when it started rounding corners.
It probably will do it again but unless i do wood or plastics on her, I can't see much work needing to go faster than 1000mm/min. - this is on aluminium with a 2mm carbide tool so pretty much the fastest CAM needed i think.
« Reply #27 on: November 29, 2016, 01:07:03 PM »
Good to hear Dave.
Looks like it really is all about acceleration.
Rob
Offline Davek0974
  •  2,606 2,606
« Reply #28 on: November 29, 2016, 01:14:44 PM »
It does, I was just babying her i think ;) Looking at the setup with it's 32mm ball screws and proper A/C thrust bearings in there now, I am confident that it will be ok.
Would be interesting to see what sort of figures are in use on the big boys vmc's.
« Reply #29 on: November 29, 2016, 01:38:05 PM »
It seems like few want to post their acceleration and velocity settings, I was look for numbers on the plasma, and managed to find Jim Colt stating 40miliG as a starting point target, and some hyperthem literature as 10miliG as a plasma minimum, hence why I was reading about centripetal acceleration
 40 miliG = 0.04 x G (~9.81m/sec) => 392.4mm/s/sec.
But not found an idiot's guide explaining the importance of acceleration in cnc world (yet)
Rob
