Hello Guest it is October 16, 2026, 02:17:22 AM
Author Topic: Error triggered Mack3 stopped working  (Read 46567 times)
Re: Error triggered Mack3 stopped working
« Reply #20 on: October 23, 2016, 07:54:35 AM »
Quote from: Tweakie.CNC
[u
EDIT[/u]  Perhaps thoroughly check your Gcode to make sure that your post-processor is not inserting some codes which are not properly recognized by Mach3.
I am using Aspire 8.502 to create the gcode so there shouldn't be any code that isn't properly recognized by Mach3.
Gene
  •  9,374 9,374
« Reply #21 on: October 24, 2016, 12:31:16 AM »
Hi Gene,
Please excuse the really dumb question but are you using the Mach2/3... post processor when saving the toolpath ?
(I already know the answer but I just had to ask).
« Reply #22 on: October 24, 2016, 06:51:35 AM »
Hi Tweakie,
Yes I use:  Mach2/3 ATC (inch)(*txt). Also I'm using screenset 2010 so I'm able to do the tool change.
  •  9,374 9,374
« Reply #23 on: October 24, 2016, 09:10:57 AM »
Hi Gene,
Sorry but more questions...
My next line of thought is referring back to your reply #5
When a Gcode file is loaded a number of things happen, one of which is to create the toolpath display.
Do you have a non-integrated video graphics card fitted in your PC ?
How much RAM does it have ?
« Reply #24 on: October 24, 2016, 10:10:02 AM »
Hi Theakie
Not sure about the video card but there are 16 GB of RAM. Never had a problem with the toolpath in the display.
Gene
« Last Edit: October 24, 2016, 10:11:40 AM by gene8522 »
