Hello Guest it is October 24, 2026, 06:19:42 PM
Author Topic: Lua Debug/Editor Key board short cuts Problem  (Read 7968 times)
Offline gorf23
  •  190 190
« on: October 18, 2016, 12:28:37 PM »
I have a script created it compiles OK But i want to step thought it, but the key board short cuts don't seem to work
I hit the F11 that should be a single step but i get nothing i get no response from any key board short cut, i have
to continually go to the drop down menu to make it step..
Is there a trick i am missing for the keyboard short cuts.
Thanks gary
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Lua Debug/Editor Key board short cuts Problem
« Reply #1 on: October 18, 2016, 12:33:20 PM »
If you have the keyboard plugin enabled try dissabling it in the taskbar.
DazTheGas
Offline gorf23
  •  190 190
« Reply #2 on: October 18, 2016, 05:44:02 PM »
Tried disabling the keyboard plugin still no keyboard short cuts
then tried disabling a couple other plugins still no keyboard short cuts
Just doesn't want to work
Thanks gary
