Hello Guest it is November 17, 2026, 01:58:35 PM
Author Topic: Slow Jog % not working  (Read 9688 times)
« on: October 13, 2016, 07:37:31 AM »
After installing a Pendant , the slow jog % do not work normally , and as the pendant are not always attached it's quite annoying
Removing the pendant and it's plug in do not help  ?   The % works fine with the pendant, but not without
Does anyone know if this slow jog % is in the XML file and if so "where" , or  any good advice on restoring the slow Jog % to work as normally
Mechman
Offline rcaffin
  •  1,073 1,073
Re: Slow Jog % not working
« Reply #1 on: October 15, 2016, 03:54:49 AM »
Odd set of faults.
Don't bother trying to hack the XML - it was not meant to be user-friendly.
Instead check the keyboard assignments for the pendant and look on the Tab fly-out page for jog details.
Pendants do work, but you have to get the codes right.
Roger
« Reply #2 on: November 03, 2016, 12:33:35 PM »
I removed the pendant plug-in , and reinstalled mach 3 ,
result absolutely no difference
I am going to create a new xml "setup file " like when Mach 3 was new and blank
I will post the result
