Hello Guest it is November 22, 2026, 04:04:48 PM
Author Topic: Lathe threading app for android  (Read 7966 times)
« on: October 05, 2016, 06:19:10 PM »
I have had an app on my android for a while which is handy for getting info on threads, the Pro version does metric, metric fine, GasRohr (BSP), Whitworth, BSF, UNF, UNEF and UNC., the free version just does metric and UNC if I recall.
Anyway I just usually used it to get end dimensions for the X when threading whether internal or external but the app could be used to produce code for some controls. Sadly the G76 code produced wasn't compatible with Mach3.
I emailed them and asked if it would be possible to get code suitable for Mach3 and they have just updated the app and you can now choose Mach3 G76 :)
I have no connection with HyperQ who do this app other than a delighted user of it.
Anyway if you want it go to Playstore and search for CTC-20Pro, it is under £5 and well worth it in my opinion.
You can download the free version (CTC-20)  if you wish to check it out but as said the thread types are limited in it.
« Last Edit: October 05, 2016, 06:21:43 PM by Hood »
