Hello Guest it is October 20, 2026, 02:51:00 PM
Author Topic: Z axis off, can't resolve the problem.  (Read 7501 times)
Offline CWB449
  •  6 6
  • CNC NUT
« on: October 02, 2016, 12:58:28 PM »
I've tried on two progams, backplotted and all my code is correct, but the cut depth is wrong on every file I load. The DRO will say I'm cutting at a depth of -0.750 but it's only cutting a depth of -0.384 (example). What in the world am I doing wrong? To be sure I calibrated Z axis and it's right on the money.
Any help would be appreciated.
  •  9,374 9,374
Re: Z axis off, can't resolve the problem.
« Reply #1 on: October 03, 2016, 12:54:19 AM »
Set Z zero and the cutter to be the top surface of the work then run your Gcode file again. Assuming the cut depth is wrong then if the Z axis is jogged (or MDI) to zero does the cutter still touch the surface of the work ??
