Hello Guest it is November 18, 2026, 12:25:19 PM
Author Topic: Screen buttons - Actions and Scripts  (Read 7359 times)
« on: September 29, 2016, 11:07:04 AM »
I have been creating some scripts by copying the script in screen buttons and using the content in other scripts.
For example the Cycle Start Gcode button has the left up script CycleStart().
However some buttons like Zero X only have button "Actions" and no script.  Do these button Actions somehow call other functions?  How can I perform the button's action from a separate script without having to press the screen button?
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Screen buttons - Actions and Scripts
« Reply #1 on: September 29, 2016, 11:20:41 AM »
If you take a look in the docs directory you will find the api.chm with all the commands in that are used within the GUI,
IE to zero an axis you would need to look at the axis section and use mc.mcAxisSetPos(number inst, number axisId, number val)
you can gain a lot of insight of using commands by looking in the modules and examples directory and reading the codes there.
DazTheGas
