Hello Guest it is November 24, 2026, 01:07:40 PM
Author Topic: A parallel port problem with mach2/3  (Read 11012 times)
remo84
« on: May 30, 2007, 02:10:50 AM »
my cnc is already works on mach2 on my computer but when i change the pc to another it doesn't work for the same config.
so  i think that the problem is in bios config. for the parallel port so i make it exactly like that one who works put still not working.
so i reverse , i mean i begin to change the bios  config. for parallel port on the pc which cnc was already work on it, i find that it works for all parallel port configuration . so i don't know what is the problem.
Re: A parallel port problem with mach2/3
« Reply #1 on: May 30, 2007, 06:56:53 AM »
what do you get when you run the driver test? and on the diagnostics page there is a DRO for TIme In Int, What is the value in the DRO?
We will see if you have the driver and after that we will check the port.
Brian
www.newfangledsolutions.com
www.machsupport.com
