Hello Guest it is October 21, 2026, 01:43:25 PM
Author Topic: Run a macro from a button press??  (Read 133352 times)
Offline Davek0974
  •  2,606 2,606
Re: Run a macro from a button press??
« Reply #20 on: September 27, 2016, 03:49:14 AM »
Ok, thanks
looks like the line should be RunScript("M889") but i had RunScript(M889)
will try again tonight ;)
Offline Davek0974
  •  2,606 2,606
« Reply #21 on: September 28, 2016, 12:25:35 PM »
Well, tried several styles of issuing a runscript command from within the macro pump and none of them worked.
The pump is running as the last attempt was...
Code: [Select]
Dim Response
If IsActive(INPUT1) Then
Response = RunScript("M889")
end if
Message "Result = " & Response
That little lot returned a value of 1, trouble is I have no idea what a result of 1 means, but it proved the pump and script is running :)
Nothing happens, no errors or any activity, if i MDI M889 it functions as expected so the target macro is fine.
Looks like runscript does not function in this version?
« Reply #22 on: September 28, 2016, 01:37:41 PM »
I remember trying this a long time ago and never got any joy but likely it was in the older versions that don't work.
See though that you are using a Mach Input, is there a reason for that? Personally I would use GetInBit(90,1) or whatever.
Offline Davek0974
  •  2,606 2,606
« Reply #23 on: September 28, 2016, 02:04:43 PM »
Thats a thought, thanks.
I'll try that way tomorrow, BUT as i said - the macro-pump does seem to be triggering its just that runscript does nothing or is not recognised?
« Reply #24 on: September 28, 2016, 02:11:36 PM »
As said I could never get it to work back in time but whether it was a broken version I tried with I am not sure as it was a long time ago.
I used MachMad from Scott Schaefer on the Beaver  Mill and it worked well, might be worth a go for all it costs.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #25 on: September 29, 2016, 03:35:31 AM »
Gonna have a poke of fun with you here Dave - but it's all done in the best possible taste  ;D
When you built your magnificent traction engines - did you have to follow any instructions? or did you just make it up as you went along?
runScript (as clearly stated in the manual) requires a fully qualified filename which is relative to the Mach install directory.
so... cutting to the chase - try this: (it works just fine here with your version of Mach3)
Code: [Select]
Const script As String = "M889"
'note: script does NOT have to be an M code
If isActive(INPUT1) Then
  If runScript("macros\" & GetActiveProfileName() & "\" & script) < 0 Then
    message "runScript failed"
  End If
End If
Note that I'm assuming you put your M889 in the macros directory for your current profile. But note that a script is NOT a macro (M code) so you can put it wherever you like.
Offline Davek0974
  •  2,606 2,606
« Reply #26 on: September 29, 2016, 03:43:19 AM »
Poke fun all you like, most of the time i ask for it ;)
Got it, it was the qualified name bit i didn't grasp, there are no examples of it in the manual at all :(
I will insert your code tonight and have a go, no doubt it will run.
BTW, the tractions engines - all you get is a set of dimensioned drawings, no instructions, no tips, how you make it is entirely up to you :)
Offline stirling
  •  2,188 2,188
  • UK
« Reply #27 on: September 29, 2016, 03:58:36 AM »
Just one potential gotcha. You haven't said (or I missed it) what your M889 macro actually does.
How long does it take to execute?
Offline Davek0974
  •  2,606 2,606
« Reply #28 on: September 29, 2016, 04:28:55 AM »
It runs a z-height sense routine using G31, the usual style - fast then slow, using a touch-plate.
Probably takes 10-15s to run.
It will certainly take longer than the button-down time so multiple runs should be avoided there if that was the gotcha?
I also need to add in some code to prevent it running if the stop LED is off i.e. in run or feed-hold modes.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #29 on: September 29, 2016, 06:23:38 AM »
OK - for that length of time and given that you only run it when no other gcode is happening, a trigger macro would be better. The problem is that you're going to be blocking the macropump. Does it matter? well - depends if you have anything else in it and how Mach will like having it blocked.
