Hello Guest it is October 15, 2026, 04:15:20 PM
Author Topic: Run a macro from a button press??  (Read 133134 times)
Offline Davek0974
  •  2,606 2,606
Re: Run a macro from a button press??
« Reply #30 on: September 29, 2016, 06:31:45 AM »
No free lunch is there ;)
There is nothing else in the pump so thats one thing, whether Mach will like it well i'll just have to see i guess :)
Definitely one of the weaker points of Mach3 though I think.
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
« Reply #31 on: September 29, 2016, 07:04:45 AM »
up to you - but I'd use a trigger - made for the job.
Offline Davek0974
  •  2,606 2,606
« Reply #32 on: September 29, 2016, 08:39:32 AM »
Is the thing with adding a macro to the INIT line, the macro has SetTriggerMacro(*********x) in it etc?
I did try that once before but it hung Mach so i thought it best not to pursue it ;)
« Reply #33 on: September 29, 2016, 09:31:24 AM »
OK, I dug this info up:
In Config >Hotkeys, set OEM Trigger #1 to 301
Create a macro named M1919.m1s and save it in MAch3\macros\yourprofile\
The contents of M1919 should be:
SetTriggerMacro(889)
In General Config, add M1919 to the Initialization String.
Setup up your button in ports and pins, Input pins, assigned to OEMTrigger #1.
Simple, huh?
Here's how this works.
The initialization string calls M1919, which tells Mach3 to assign M889 as the Trigger Macro. The 301 in Config Hotkeys tells Mach3 to run the macro assigned with SetTriggerMacro when the OEMTrigger is activated (your button).
Offline Davek0974
  •  2,606 2,606
« Reply #34 on: September 29, 2016, 09:39:44 AM »
Thanks Gerry, Stirling,
Yes that was what i tried before but after adding the macro to the INIT line, mach would not start again, I had to revert to a backup to get going again then aborted trying to get this working that way, I will try again tonight.
Another oddity, after messing with editing the macropump macro, Mach seems to get a bit pissed and does odd things like starting up code with no M3 so no spindle, MDI and M3 and you get the script compiler error message, restart Mach and its happy again. Done this a few times now - is it a bad idea to edit the macro pump file while Mach is running?
« Reply #35 on: September 29, 2016, 09:53:37 AM »
You must have had an error in your macro that you called from the init string.
When I wrote the above info two years ago, it worked.
Offline stirling
  •  2,188 2,188
  • UK
« Reply #36 on: September 29, 2016, 10:09:04 AM »
If you suspect issues with the init string macro, then the simple way to TRY it is just to set your ports and pins for trigger1 and then set 301 as the OEM code in hotkeys. Then just do the setOEMTrigger 889 in the CB editor. At that point you can test your trigger.
The only reason for putting the trigger config macro in the init string is so that it's set each time you start Mach.
If that works THEN do the init string macro.
re: editing the macropump macro: There should be no issue because the macropump macro is compiled (as opposed to "regular" macros/scripts which are interpreted). The compilation is done when you start Mach so the edited version means nothing until you re-start Mach. i.e. there's no issue with you over writing it as it's running if that's what you're wondering.
Absolutely agree. It works here now and it worked when I wrote this 6 years ago.  :P
http://www.machsupport.com/forum/index.php/topic,15120.msg101160.html#msg101160
Offline Davek0974
  •  2,606 2,606
« Reply #37 on: September 29, 2016, 12:52:59 PM »
All sorted, and it works :)
Must have been an error last time, i've turned off the macropump as there was nothing else in the macro, trigger works nicely.
Thanks all for the assistance.
« Reply #38 on: August 25, 2018, 03:02:56 PM »
Hey guys, im sorta after the same thing here, i have a pnumatic clamp that i lock with m20 and unlock with m21, i need to activated this with a hardware momentary button that does the opposite to the current state, so if m20 is active pressing the button will toggle it to m21 and visa versa, any help would be appreciated.
Offline TPS
  •  2,627 2,627
« Reply #39 on: August 26, 2018, 03:08:54 AM »
you have to create a "Memory" to know the Output is on or off.
for example:
add to M20:
SetUserLed(1800,1)
add to M21:
SetUserLed(1800,0)
and the button script:
If GetUserLed(1800)=1 Then
  SetUserLed(1800,0)
  DeActivateSignal(your clamp Output)
Else
  SetUserLed(1800,1)
End If
not tested, just written down.
