Hello Guest it is October 22, 2026, 05:54:54 PM
Author Topic: Setting up tools in tool table  (Read 9555 times)
« on: September 10, 2016, 06:00:18 PM »
I'm a noob sorry...
Ok so when trying to load my first 1/4 end mill and set tool offset.... I save general info in tool page, Tool #1 name and 1.000 height and it saved fine.
So then i click on "set tool offset" under gage block height to input the "0.005" for my detection piece... when i then click on the tool number block to input tool 1
the gage block info goes back to 0.000. I have tried this multiple times and in the reverse order choosing (or typing) 1 in tool # box first then gage block and the same happens.
I am on a demo version but it doesn't say you can't save tools so why is this happening?
I have watched this vid ( https://www.youtube.com/watch?v=Ne9aQgcjfUo ) to do this and at the 5:45 mark you can see his machine has 0.0050 already set in the Gage block height setting... that is what i need to have saved then continue on but like i said i can type it in but no matter what even if I hit Set Tool offset button the info disappears or if/when I try to change to tool 1
Offline Stuart
  •  311 311
Re: Setting up tools in tool table
« Reply #1 on: September 11, 2016, 05:05:31 AM »
Wrong info sorry
« Reply #2 on: September 12, 2016, 03:17:51 AM »
did you restart mach3 after making changes, its not always neccessary, just a thought
