Hello Guest it is October 24, 2026, 12:01:42 PM
Author Topic: Spindle won't stop on reset  (Read 14743 times)
« on: May 28, 2007, 08:44:32 PM »
Hi Guys,
It's been a while since I last posted. I am having a problem and need some help.
I have set the esc key to the reset function. All axis stop fine and the program
stops execting when I press the esc key, but my spindle will not turn off. What
do I need to do to get the spindle to stop also ?
Thanks in advance.
Al
Re: Spindle won't stop on reset
« Reply #1 on: May 28, 2007, 09:54:52 PM »
You will need a DoSpinOFF()
That should do it
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: May 28, 2007, 10:05:16 PM »
Brian,
Does that need to go in a Visual Basic script ?
Where and how please ?
Al
« Reply #3 on: May 28, 2007, 11:04:34 PM »
Something wierd going on here.
If I set up the F2 function key for reset every thing works
fine including stopping the spindle.
Any guesses what's going on ? Is there a reason the esc key can not
be used for the reset function ?
Al
« Reply #4 on: May 29, 2007, 12:50:12 AM »
Al, unless it has to be the F2 key I would set it back to the default. It is the ~` key, beside the 1 at the top. You may have to dissect the whole screen set to see what the interference is or maybe your system hot keys, or just a windows things.
« Reply #5 on: May 29, 2007, 08:02:12 AM »
The esc Key is not something that you should  use :( The Esc key is hard coded into the software as a STOP NOW in Gcode moves... I would  use the ~ key.
Brian
www.machsupport.com
« Reply #6 on: May 29, 2007, 10:59:54 PM »
Thanks Brian,
That would explain the problem. I thought I had this working with the
esc key at one time but that may have changed in some of the
latter Mach versions.
Al
