Hello
Guest
it is
October 24, 2026, 05:19:39 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Finding the middle of a circle.
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Finding the middle of a circle. (Read 25053 times)
Smackre
57
Re: Finding the middle of a circle.
Reply #10 on:
May 29, 2007, 01:43:01 AM »
Ok due the lack of sleep and being alittle bit rushed I clicked on the wrong wizard. I have now found the wizard you are talking about. And it looks exactly like you showed it to be. Thanks for the help. I am going to go try it and then prolly go to bed ! Once again thanks for the help.
Reply #11 on:
May 29, 2007, 01:58:02 AM »
When you go to the wizards do you see the same as I have in the first image, ie circle centre V1 by German Bravo ??
Reply #12 on:
May 29, 2007, 01:59:49 AM »
ahh ok, sorry missed your last post, let me know how you get on. I have not used it as I cant use the MPG to jog but I must modify the screen so I can do so as I think I too will find it a very useful wizard.
Smackre
57
Reply #13 on:
May 29, 2007, 03:07:00 AM »
It works very well. I milled a 1" slot in a peice of wood. and put a 1" steel pin in it. Then i found the middle and it was within .002 of the center if the hole. As accurate as I will ever need it. I will be using this alot now that i know how useful it is. This is the first time ive used the Mill a Circle wizard to. It worked nicely to. Saves alot of time when all you want to do is mill a slot or hole or something and dont wanna half to program it.
Thanks for all the help.
Reply #14 on:
May 29, 2007, 12:22:11 PM »
Thanks for the info, this has spurred me on to modify the screen so I can use my MPG in the wizard, also I will have to finish my probe/edgefinder now LOL
Print
Pages:
1
2
Go Up
« previous
next »
