Hello Guest it is October 21, 2026, 07:56:26 AM
Author Topic: PicEngrave & Impact Engraving  (Read 44798 times)
Re: PicEngrave & Impact Engraving
« Reply #20 on: September 14, 2016, 11:27:08 AM »
The laser variable feedrate replaces the Z with a F. The Feed Rate Change adds the Z depths and the F for variable feedrate at the end on each line of gcode.
If the Feed Rate Change feature was available, there would be an input for the feedrate percentage and a selection to add it or not. I don't see that in the screenshot.
Jeff
Extensivly Re-worked/Re-designed/Modified Servo K2CNC KG-3925 and the Mini Laser Engraver
« Reply #21 on: September 14, 2016, 11:39:15 AM »
Here it is.
« Reply #22 on: September 14, 2016, 11:42:18 AM »
Does the 3rd Axis letter change to a F when selected?
« Reply #23 on: September 14, 2016, 11:44:11 AM »
Yes.
« Reply #24 on: September 14, 2016, 01:58:38 PM »
Rob
Albert Einstein ― “If you can't explain it to a six year old, you don't understand it yourself.”
« Reply #25 on: September 14, 2016, 11:41:56 PM »
That is nice, but I am not familiar with UCCNC and won't be changing over from Mach3 to something that isn't proven in my opinion.
« Reply #26 on: September 16, 2016, 07:31:03 AM »
Is it possible to control the resolution of dithering? I am now able to get fair results, but would like higher resolution. I am trying to engrave an image on a small pendant so the image size is about 25x25mm (1"x1"), but after the image is scaled down to this size and I perform dithering, the dots I get are very coarse and the image looks poor. With a larger image the dots remain the same size, but considering the larger image size it looks fine.
« Reply #27 on: September 16, 2016, 08:29:29 AM »
Try increasing the DPI resolution in another image editor before opening it in the PEP editor to dither. Also experiment with the Atkinson dithering algorithm as it's adjustable.
Jeff
« Reply #28 on: September 16, 2016, 08:32:14 AM »
Increasing the DPI using GIMP, but it affects the size of the image, so that I have to scale it again using PEP. Played with Atkinson but it doesn't give what I want.
« Reply #29 on: September 16, 2016, 08:45:51 AM »
I use Corel Photo Paint and it lets me increase the DPI without effecting the size. Good case of you get what you pay for.  ;D
