Hello Guest it is November 03, 2026, 10:12:25 PM
Author Topic: MIKRON WF3 RETROFIT  (Read 150215 times)
Re: MIKRON WF3 RETROFIT
« Reply #30 on: September 25, 2016, 06:39:01 AM »
the linear scales works now with the controller and the heidenhain EXE 602 adapters and the spindel too,
but i have problems with the amps and the setup for the axis with the pid tuning and moving the axis.
i can`t login in 2  of the kollmorgen 603 amps with the kollmorgen drive software and one csmio output are not at 0v. i change the shield cable with the shortest line to the csmio, but its the same shift (100mv). i can correct this with the software (in the servo am or csmio) , but it isn´t the right way.
the same problem as slovenic with the spindels?
http://www.machsupport.com/forum/index.php/topic,32308.0.html
« Last Edit: September 25, 2016, 06:45:51 AM by gravie »
« Reply #31 on: September 28, 2016, 11:17:38 PM »
how can i activate (easy) a solenoid with a (digital) input button (IO modul) and an digital output (csmio-a unit)?
with a vb script or with brain or easy in the mach menu?
i want also activate the toolchanger solenoid (output CSMIO-A unit)  with a button (connected to the  io modul ) after the m6 command.
« Last Edit: September 28, 2016, 11:24:21 PM by gravie »
« Reply #32 on: October 01, 2016, 09:59:44 AM »
the tool clamping works now with a simple brain.
i can´t find a M3 button in the software ....how can i turn the spindle on with an external button?
with a "send string to plc" command in brain?
and can i use the csmio-ip  i/o`s direct with brain commands?
« Reply #33 on: October 22, 2016, 07:00:18 AM »
i fitted the ball screws at the x and y axis, but the cheap micron spindels arent backlash free.
the pid tunings works now much better as with the old trapeziod spindles.
i changed today to the mach 3 62 version in an different folder.
how can ich transfer the cs labs settings to the new folder?
i have now problems to start the pid tuning, but the plugin works.
« Last Edit: October 22, 2016, 07:04:34 AM by gravie »
« Reply #34 on: November 01, 2016, 05:49:06 AM »
Where did you buy the spindles ?  Did you bought the spindles longer then they were in original ?
I have bought new motors and meanwhile im waiting for the motors im going to prepare everything for the belts.
« Reply #35 on: November 01, 2016, 09:17:30 AM »
i bought the 3205 spindles from smalltec, germany, but the spindels are micron/ukraine
http://www.micron.ua/en/products/ball-screws
i think, hiwin spindles are better qualitiy.
the spindles are longer than orignal.
i can send you drawings for the parts.
« Last Edit: November 01, 2016, 09:20:43 AM by gravie »
« Reply #36 on: November 04, 2016, 02:31:39 PM »
Did it cost alot of money ?
How hard is to change the spindles ? Are you considering also to replace the Z?
Yes that would be great . Im waiting for the motors now.
Thank you for your help so far !
« Reply #37 on: November 05, 2016, 10:48:50 AM »
yesterday i found the controller for the original dc motors in an hungary ebay shop.
160v and 30a >:(
https://www.youtube.com/watch?v=No__uUdG1yY but not for  the csmio ip A
http://www.cncdrive.hu/shop/index.php?productID=459
http://shop.cncdrive.com/
the shop sells cheap spindles too.
« Last Edit: November 05, 2016, 10:59:06 AM by gravie »
« Reply #38 on: November 16, 2016, 10:58:22 AM »
the first run with the new z-axis spindle.
« Reply #39 on: November 27, 2016, 02:15:05 AM »
this is the gear shifter
is ist a possibility to run it with a brain or works this only with an vba script?
i need/have:
6 inputs for the switches (only for controlling)
6 outputs for the position (to the faller servo box with programmed postions)
1 output for the spindle motor ( to the frequency inverter with an input for a fixed speed , 20 1/min for better gearing)
