Hello Guest it is October 20, 2026, 08:00:08 AM
Author Topic: how do i mod the m6 script to issue a m5  (Read 8879 times)
Offline Stuart
  •  311 311
« on: August 17, 2016, 05:00:50 AM »
as above
my setup does all the correct things for a tool change box comes up ( i have not cancelled this yet ) led flashes with request to press cycle start
OK it all works H offset is correctly applied
what line of script do i put into the Lua m6 command to stop the spindle to allow the tool change
i get round this by stopping the spindle with the button on the right
Thanks in advance
Stuart
Re: how do i mod the m6 script to issue a m5
« Reply #1 on: August 17, 2016, 05:42:58 AM »
You're g-code should be stopping the spindle before it gets to the tool change.
Offline Stuart
  •  311 311
« Reply #2 on: August 17, 2016, 06:16:55 AM »
Thanks for the reply I will get on to Fusion 360 Team for a post mod
Thanks again
Stuart
« Reply #3 on: July 27, 2017, 05:02:05 PM »
Stuart,
Did you ever manage to get this issue fixed?
I am having the exact same issue.
Offline Stuart
  •  311 311
« Reply #4 on: July 28, 2017, 05:32:24 AM »
if you are using Fusion 360
then the latest PP fixes it
and the latest mach4 release sorts it
link http://cam.autodesk.com/posts/
type in Mach4 into the search box
