Hello Guest it is November 13, 2026, 03:45:22 PM
Author Topic: Change direction of the work area  (Read 28915 times)
Offline AGOMA
  •  10 10
Re: Change direction of the work area
« Reply #10 on: August 17, 2016, 12:28:55 AM »
Yep. It's unchecked.
.. I tried to check it also..
Offline AGOMA
  •  10 10
« Reply #11 on: August 17, 2016, 08:26:46 AM »
I've googled and YouTubeed but I can't get it to work.
Does anyone have an idea what I'm missing?
Offline Davek0974
  •  2,606 2,606
« Reply #12 on: August 17, 2016, 09:22:14 AM »
You have a switch on main axis and on slave axis, and they show up in Mach when triggered?
If yes then it has to be a software setting.
Offline AGOMA
  •  10 10
« Reply #13 on: August 17, 2016, 09:30:15 AM »
Yes I have and yep they do.  :)
Feels like I have tried everything.. Well I will start over.
From the top  :D
Offline Davek0974
  •  2,606 2,606
« Reply #14 on: August 17, 2016, 09:42:48 AM »
Before you do that, have a read here, may find some answer....
https://www.machsupport.com/forum/index.php?topic=25867.0
Offline AGOMA
  •  10 10
« Reply #15 on: August 17, 2016, 10:04:53 AM »
Thanx.
I will try to set up the B axis instead, just to be sure..
Offline AGOMA
  •  10 10
« Reply #16 on: August 21, 2016, 03:44:04 PM »
Hello.
Seems like my UC300 isn't compatible with homing a slave axis separated.
I'm trying to swap axis, but can't get this to work either..
Does anyone have code for this.?
I have found some but they didn't work.
I've started with dooembutton for z then y then x with slave a.
Then swapaxis a with b and dooembutton for home b then reset swap..
..but no success :(
Big thanx..
« Reply #17 on: August 21, 2016, 03:50:07 PM »
Best to confirm SwapAxis() is supported by your controller, good chance it is not.
If you contact the maker they will be able to tell you and if it does support it they can tell you the proper way to do it.
« Reply #18 on: August 21, 2016, 05:26:31 PM »
The UC300 manual list supported Mach3 functions, and SwapAxis() is not on the list.
Slaving is, though, and slaved homing should work.
Offline AGOMA
  •  10 10
« Reply #19 on: August 22, 2016, 04:49:58 PM »
Thanx guys.
I've tried a couple of things. I and I did get the swap axis to work. So that's good, and I can see in pins and ports that they have mowed from a to b, I and then back to a after reset swap. But the b won't home during doOEMbutton.. Yhy? The Uc300 shouldn't care about that, only what is locked in pins and ports ? Again, thanx all for your help!  ;D
